oil pan gasket for tpc pan
Does the tpc pan use a stock ls1 gasket ? I have to drop mine to add a new oil pump and timing chain for a new cam. This is a sickness !!! The car does not yet run but one thing leads to another and it went from just getting it together ( it was someone else's unfinished project ) to an new intake and throttle body, cam, springs, push rods, oil pump, timing chain and sprockets, valve seals etc. etc.
I have had the car for 5 months but just getting to work on it, the parts are stacking up, all of the brake parts were sourced from Kent and are waiting to go on too.
Any way any help on the gasket would be appreciated so I can get whats needed if it's not the factory type.
Jim
Moderators I wrongly posted this in the conversion section and will try to remove it from there, if I can't please remove the double post.
Jim
Jim
Jim
hutchjc1- Posts : 68
Re: oil pan gasket for tpc pan
Nothing special about the gasket, standard LS oil pan gasket is what you need.
Techno Duck- Posts : 447
That's what I was looking for thank you for your time !
Jim
Jim
