steering shaft question
I have seen mention of maintaining the clocking of the steering shaft while adding the length for the spacers, on the car I bought the PO had started to lengthen the shaft but started out by cutting it. I have no way to tell where it should be clocked from on end to the other, does anyone have info on this subject that they could share ? With a splined shaft does it really matter, the only thing I think it would get you is access to the bolts with out having to turn the wheels, is there more to it ? It is a 1986 turbo if that matters......
Thanks for any help,
Jim
Jim
hutchjc1- Posts : 68
Re: steering shaft question
ya, there is more to it than that. If it's not "clocked" properly, it'll bind and jam up. The u-joints have to be indexed from each other. just use a original one as a reference.
murrayg- Posts : 105
