» Heat stuck on high
Brake parts FS: 944 Brembo, Tilton bias & master cylinders EmptyYesterday at 2:11 am by Porsche951toLS3
» Selling TPC LS Swap Kit + Ceramic Headers + SPEC Clutch / Flywheel + Hydroboost + More
Brake parts FS: 944 Brembo, Tilton bias & master cylinders EmptyFri Jul 19, 2019 11:42 pm by matt889
» WTB: TPC LS Swap Kit
Brake parts FS: 944 Brembo, Tilton bias & master cylinders EmptyFri Jul 19, 2019 11:24 pm by Zach968
Brake parts FS: 944 Brembo, Tilton bias & master cylinders EmptyWed Jul 17, 2019 10:02 pm by sharkey
» Hydroboost low pressure port
Brake parts FS: 944 Brembo, Tilton bias & master cylinders EmptyWed Jul 17, 2019 3:03 pm by rdanford
» Alfa Romeo 2.5L V6 --> '78 924
Brake parts FS: 944 Brembo, Tilton bias & master cylinders EmptyMon Jul 15, 2019 5:11 pm by porschekid7
» WTB: LS Swapped 944
Brake parts FS: 944 Brembo, Tilton bias & master cylinders EmptyMon Jul 15, 2019 4:57 pm by porschekid7
» 1987 Porsche 944 S - Transaxle FOR SALE
Brake parts FS: 944 Brembo, Tilton bias & master cylinders EmptySun Jul 14, 2019 12:55 pm by MotoRider42HC
» V8 Swap Project Car Swap Out
Brake parts FS: 944 Brembo, Tilton bias & master cylinders EmptySun Jul 14, 2019 6:12 am by DirtRocket
» Transaxle rebuild
Brake parts FS: 944 Brembo, Tilton bias & master cylinders EmptyFri Jul 12, 2019 8:12 pm by Jasonscottw
July 2019
Brake parts FS: 944 Brembo, Tilton bias & master cylinders Empty Brake parts FS: 944 Brembo, Tilton bias & master cylinders
Post  Sterling Doc on Fri Nov 27, 2015 9:27 pm
Lots of leftover parts from the Franken44 build
Master cylinders in 7/8, 15/16, and 1" sizes. I have reservoirs, and hardware for 2/3 of them. All have only testing use on them 2 track days or less. About $100 each new. $125 shipped takes them all, and all the hardware.
Tilton bias adjustor - just the adjustor itself. $60 shipped
944 Turbo front Brembos from a 1986 944 turbo. Cosmetically only fair, but mechanically sound. Rebuilt with new seals last 1/2 and then had 4 events use before they were taken off. $250 shipped.
Sterling Doc
Brake parts FS: 944 Brembo, Tilton bias & master cylinders Empty Re: Brake parts FS: 944 Brembo, Tilton bias & master cylinders
Post  kevin924kevin on Wed Oct 25, 2017 1:14 pm
do you still have?
