Cluth Ram 92955
Cluth Ram 92955
I found a set of clutch Ram 92955 .Does he fit the conversion ? What flywheel to him with Lt1 350 engine ?
Pavka944- Posts : 17
Re: Cluth Ram 92955
That listing is for the newer 5.0 Mustang. I would contact TPC for a clutch disc that uses the 944 spline hub. Look on summit racing for flywheel and PP listings for LT motors.
Re: Cluth Ram 92955
948 wrote:That listing is for the newer 5.0 Mustang. I would contact TPC for a clutch disc that uses the 944 spline hub. Look on summit racing for flywheel and PP listings for LT motors.
LT1 motors use a pull type pressure plate. He'll need a push type, any flywheel from an 86+ SBC 1pc main seal (externally balanced).
Cluth ram 92955
Should i use pull clutch set with Lt1 engine flywheel ?Ram clutch 92955 have input shaft 1" and 23 spline ; its similar for Porsche .
