» Dual MC Mounting Bracket
Yesterday at 8:11 pm by 87944turbo
Yesterday at 7:50 pm by hp18racer
Yesterday at 5:20 pm by dougr944
» Need help! Car won’t start
Yesterday at 3:51 pm by jess2suityou
Yesterday at 9:44 am by keetle
» Brand new ls3 build
Yesterday at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Yesterday at 1:35 am by Porsche951toLS3
January 2019
78910111213
14151617181920
21222324252627
28293031
Engine fails when getting warm under load or idling
Post  quarterflash on Mon Nov 23, 2015 3:59 am
Hi everyone
We had our first frost of the year here in the UK last night. Brrr.
Maybe you can suggest a solution to our problem.
Engine: 95 Corvette LT1 350.
Car: 89 944 Turbo, well it was.
Problem: engines takes a while to start but then fires up and runs fine. However after driving for a short while or even idling it splutters to a halt. Leaving it to cool down allows us to start it again no problem.
I don't want to put ideas in your head but does that sound like a coil issue?
All cylinder compressions are good (175 - 200) and it is not restricted to a cylinder or even a bank of 4. The whole engine is affected so it has to be coil, distributor or fuel?
All ideas welcome.
Q
quarterflash
http://porschevy.co.uk/
Re: Engine fails when getting warm under load or idling
Post  spence on Mon Nov 23, 2015 5:07 am
Sounds like an optispark or ICM issue.... Read this
Post  kelleysj on Thu Dec 10, 2015 8:37 am
I had this issue with my ICM. I spaced the heatsink with washers since I believed it was overheating due to being mounted to the driver side head. I also removed the ICM from the heat sink cleaned all the old paste off and added Artic silver5 heat sink paste to the sink and ICM remounted it. Since I have done this I have not had one problem with the car dying. This is a cheaper fix to try first before messing with the opti.
kelleysj
Post  quarterflash on Thu Dec 10, 2015 8:51 am
Thanks for your help kelleysj. However the diagnostic that has been run since posting this problem indicates an Optispark issue. So a shiny new unit is on its way. I will post the answer when we get it sorted.
Incidentally where have you mounted the ICM. Looks like mine will be under the dashboard with the two brake servos.
Regards
Q
quarterflash
Post  spence on Thu Dec 10, 2015 10:54 am
What kind of optispark did you buy? I hope you got an MSD or AC delco OEM replacement.... Anything else is crap and wont last.
Post  quarterflash on Thu Dec 10, 2015 11:10 am
It was a difficult decision - do I spend £380 or £180? Especially as I suspect MSD and Ac Delco is made in china these days.
Regards
Q
quarterflash
Post  spence on Thu Dec 10, 2015 11:18 am
Yes, the MSD and AC delco cost is more; but I'd still go with those. It's not worth having to pull everything off the front of the engine to do it again... The cheap ones are known for having issues right out of the box.
