» alignment specs
Today at 12:53 am by sharkey
Yesterday at 9:46 am by JSP
» Transaxle rebuild
» Tpc LS adapter plate
Cluth Ram 92955
Cluth Ram 92955
Post  Pavka944 on Tue Nov 17, 2015 12:37 pm
I found a set of clutch Ram 92955 .Does he fit the conversion ? What flywheel to him with Lt1 350 engine ?
Pavka944
Re: Cluth Ram 92955
Post  948 on Thu Nov 19, 2015 10:27 am
That listing is for the newer 5.0 Mustang. I would contact TPC for a clutch disc that uses the 944 spline hub. Look on summit racing for flywheel and PP listings for LT motors.
Re: Cluth Ram 92955
Post  spence on Thu Nov 19, 2015 3:02 pm
948 wrote:That listing is for the newer 5.0 Mustang. I would contact TPC for a clutch disc that uses the 944 spline hub. Look on summit racing for flywheel  and PP listings for LT motors.
LT1 motors use a pull type pressure plate. He'll need a push type, any flywheel from an 86+ SBC 1pc main seal (externally balanced).
Cluth ram 92955
Post  Pavka944 on Fri Nov 20, 2015 11:19 am
Should i use pull clutch set with Lt1 engine flywheel ?Ram clutch 92955 have input shaft 1" and 23 spline ; its similar for Porsche .
Pavka944
Re: Cluth Ram 92955
