Scca Xp solo build
+4
hutchjc1
gdopnt
racertomtom
scryfst
8 posters
Scca Xp solo build
Haven't posted the new project on this forum, thought it was time.
Build thread: [You must be registered and logged in to see this link.]
Website: [You must be registered and logged in to see this link.]
Follow on facebook as well @ [You must be registered and logged in to see this link.]
It's DONE
The new solo car is finally done. Not in time to run this season but, complete. Here is a little teaser, I'll post more in the coming week.
Link to video of the car idling.
Re: Scca Xp solo build
I had been eagerly watching your build and I am glad to see it finished. The car is an excellent display of skills and ability. Sounds mean as well. Good job and I hope you do well with it.
I would have liked to have seen a simple weld-in roll bar. Harness bars are too risky for my taste.
racertomtom- Posts : 144
racertomtom wrote:I had been eagerly watching your build and I am glad to see it finished. The car is an excellent display of skills and ability. Sounds mean as well. Good job and I hope you do well with it.
Your kind words are appreciated.
If the car ever is used for anything other than Solo racing, it will be caged.
Do i see supports for the transaxle back there
gdopnt- Posts : 127
gdopnt wrote:Do i see supports for the transaxle back there
Yup.
Very Nice ! Good luck and enjoy it !
hutchjc1- Posts : 68
scryfst wrote:gdopnt wrote:Do i see supports for the transaxle back there
Yup.
Did you also make your own trans crossmember? Or did you box it in? I don't remember how the factory piece looks off the top of my head.
Halfkiddio- Posts : 12
Halfkiddio wrote:scryfst wrote:gdopnt wrote:Do i see supports for the transaxle back there
Yup.
I boxed the factory. Also using the "Super" mount available from Pelican (at least it used to be).
This is kinda cool!
So, I had a small engine issue. One of the CNC ported heads I used had a flaw in the casting. Here is the story...
This is the third engine I've built using Texas Speed & Performance components. Not only have the parts been great, so has the customer service. Their handling of this problem has been no exception.
This engine is using the PRC 5.3L stage 2.5 CNC'd heads. Used for the small chamber size.
While inspecting after initial start-up a puddle of coolant in the #2 plug bore caught my attention. Hoping I'd just spilled a small amount of coolant when filling(although I knew I hadn't) it was cleaned and left to sit overnight. The next morning I had a new puddle. Damn.
Called Texas Speed and even though it had been over a year since I purchased the heads I was taken care of. After confirming the flaw, I was sent a new head, gasket, and bolts.
All back together. Spring can't come soon enough.
You have an amazing car. Beautiful build.
Kudos to Texas Speed and Performance. I have used them a few times myself.
Good to know they stand behind their work. They are where I have been planning to send my heads once I find time to pull the engine apart.
erioshi- Posts : 227
Boost Bros. on Widerstandsfahig
I was able to finally start testing the car this Sunday. A special guest came out to take a look...Enjoy!
I have read a little on transaxle supports and I was wondering if you saw any benefits from bracing it and also any negative side to it?
Are you just running coilovers? or torsion bar also?
I also like your painted hood vents, what brand are they?
Awesome build!
Awesome build!
yamamtx- Posts : 97
yamamtx wrote:I have read a little on transaxle supports and I was wondering if you saw any benefits from bracing it and also any negative side to it?
Awesome build!
The transaxle supports were recommended by numerous fellow racers. The trans tends to rotate under heavy load largely dependent upon the type mount used. It was found that the rotation was causing CV joint issues (sometimes catastrophic). I've used the "super" mount from Pelican and the supports pictured. Because my seat time is limited to date in the car, I can't give an honest opinion on the performance.
Coilovers- Yes, all four, no torsion bars.
Hood vents- The hood is a one-off I've made. The vents are not applied, they are part of the hood that weighs 12lbs.
Thanks for the info. Great looking car!
yamamtx- Posts : 97
Today at 9:56 am by ndog52
