» Transaxle rebuild
» Hello, Gentlemen.
Yesterday at 7:43 pm by rawr
» alignment specs
Oil pan issue
Oil pan issue
Post  Jim7 on Tue Nov 10, 2015 4:58 pm
When I began the project I was determined to dry sump the engine and after spending substantial coin I realize it's not feasible.  So it's back to a wet sump and I checked out the various possible OEM pans and found the truck L31 offered the best possibility.  I like the idea of the OEM as it has all the plumbing we want and it's a structural member of the engine too.  So I found a pan for dirt cheap and cleaned it up and bolted it on and found it's very close to a fit  It needs cutting in about 3/4" of an inch at the crossmember.  The pan itself is really deep and is about 1 1/2" lower than the crossmember lowest point.  So here's the questions.  Has anyone cut and welded an oil pan? How did it hold up?  Is the truck pan too low?
Jim7
Re: Oil pan issue
Post  Arthropraxis on Tue Nov 10, 2015 6:55 pm
If you have a LS944 you have a cut and welded oil pan. They hold up fine, as long as the welds are quality.
Re: Oil pan issue
Post  Jim7 on Tue Nov 10, 2015 7:39 pm
Whats an LS944 oil pan? The one that I was using was a Moroso dry sum pan.
Jim7
Re: Oil pan issue
Post  docwyte on Wed Nov 11, 2015 9:38 am
The Easy Button is to buy an already modified oil pan from Texas Performance Concepts.
Re: Oil pan issue
Post  Jim7 on Wed Nov 11, 2015 6:32 pm
The easy button was broken a long time ago. Also i discovered that while they appear the same there are subtle difference between the 944 and 968s. Mine of course is the 968. Anyway i took the pan to the welder and he said I should go to the machinist to get the thing cut.  So I did that and fortunately I've done a fair bit of business with him and he looked at it and shook his head, as in PIA, but he said he'd do it and get it welded too. So the part of pan over the crossmember and rack will be chopped by .75" with a .125 aluminum plate welded in and the reservoir part of the pan will be sectioned by 1.75".  I just have to wait for him to get in the mood but he works magic with metal and is very good with the tools. He's an original Brit machinist, old guy like me. I can hardly wait. In the meantime I'll get the LS6 valley cover and an adapter to the pan for the AN10 oil cooler lines. I getting excited again.
Jim7
Re: Oil pan issue
Post  matt889 on Thu Nov 26, 2015 11:34 am
Keep me posted on measurements!
matt889
Re: Oil pan issue
