WTB: LS2 Intake Manifold/Rails/Inj; Tilton/Wilwood short master cylinders
Hey folks,
Looking for an LS2 intake manifold, ideally with the rails and injectors from a GTO or Corvette. Do not need the TB.
Also, there have been a number of folks trying various sized master cylinders for their Dual Master setup. Hoping you may have some lying around that happen to fit my needs (given that they're non-returnable).
I'm looking for 5/8", 7/10", and 3/4" bore sizes. The short, 1.1" stroke MC's with provisions for remote reservoirs.
Thanks in advance!
Thanks in advance!
ausgeflippt951- Posts : 70
Re: WTB: LS2 Intake Manifold/Rails/Inj; Tilton/Wilwood short master cylinders
Don't have what you're looking for but I went through the LS2 intake manifold hunt a couple months ago. No reason to pay more than $400 for manifold + injectors + fuel rail. I bought all items separate and ended up just below $400.
The forums almost always have injectors ~$50 cheaper than ebay. Check gto forums, LS2 forums, LS1 tech, etc. I got impatient waiting for a set so I went the ebay route. Post a WTB ad if you can on various forums.
Just an FYI on whats reasonable..
FrostedFlakeJake- Posts : 263
Thanks Jake -- you're absolutely right. I was able to procure a new manifold, new fuel rail, and used injectors for <$400 but it did take some searching.
» Brake parts FS: 944 Brembo, Tilton bias & master cylinders
» Spec clutch setup and master cylinders
» FS. Brand new LS6 intake manifold
