» Tpc LS adapter plate
» Headers, headers, HEADERS!
Got my donor car, question on pulling the motor.
Post  Arthropraxis on Wed Oct 14, 2009 2:01 pm
When pulling the motor using the clarks garage instructions is there anything I should be aware of. I read I should keep the oil pressure and water sensors and pigtails. Any other suggestions?
Re: Got my donor car, question on pulling the motor.
Post  gt1scca on Wed Oct 14, 2009 2:28 pm
If selling the 944 harness is not a priority, keep the DME firewall grommet and the 14-pin section of the engine harness. These will make tying into the Porsche wiring much simpler.
944 PS pump.
PS Reservoir.
Crankshaft pulley.
(These can be used for properly setting up the 944 PS...with custom brackets and a little work.)
Cam Gear.
(for VSS...)
Sensors can be adapted, of course.
(sensor wiring connects through the above mentioned 14-pin harness section...located above the power brake booster...)
Post  Arthropraxis on Wed Oct 14, 2009 6:24 pm
I will just keep everything until I know what I don't need. The cam gear was already parted when I got the car. The PO had taken some parts off to sell already.
Is the Clark's Garage a good guide to go by?
Motor is coming out in the morning.
Post  Arthropraxis on Fri Oct 23, 2009 9:23 pm
I have everything unhooked now, borrowed a hoist and I am ready to drop it in the morning. Anybody have any helpful tips not in the factory manual?
Post  RobotMachines on Sat Oct 24, 2009 11:08 am
You'll do fine, just take it slow. Only thing to really be aware of is to not get hurt.
But, the most important thing to do is to grab some pictures of your progress Very Happy
RobotMachines
It is out.
Post  Arthropraxis on Sat Oct 24, 2009 8:04 pm
That was easier than I thought it would be. Now which motor LS1 or L33?
Post  RobotMachines on Sat Oct 24, 2009 8:16 pm
arthropraxis wrote:That was easier than I thought it would be. Now which motor LS1 or L33?
I have a lot of fun with an LT1 but, if you can afford more power, go for it. Twisted Evil
RobotMachines
