1984 Tach wire
1984 Tach wire
Does anyone know what color wire on the tach to use to to tap the pcm wire into?
I have the early gauge cluster and there are numerous wires on the back to the tach.
wanczykj- Posts : 41
Re: 1984 Tach wire
Did you find the correct wire. Same question.
Sent from Topic'it App
keetle- Posts : 4
Re: 1984 Tach wire
That info in in the "Wiki", up at the top of the page 2nd tab from the left.
http://944hybrids.pbworks.com/w/page/1147183/944%20Pin%20Connections
LEFT LUG = + [Positive]
CENTER LUG = SIGNAL [Input]
RIGHT LUG = - [Negative]
Today at 12:47 am by sharkey
