Thermostat Temp
Thermostat Temp
Is there a preference for a 165 deg or 180 deg stat? Is there any accepted thinking on the choice of temp for an LT1. If lower temp, is there some reasoning. I've searched and couldn't find any definitive answer.
944-v8- Posts : 59
Re: Thermostat Temp
I'm going with the 165 deg stat and programming the ECU to run fans.
944-v8- Posts : 59
Re: Thermostat Temp
If it is street driven, stock temp is fine. A high flow tstat would be a plus. With these cars some find that the cooling system is not sized well for the V8. If that is the case then a low temp tstat will have little impact as the system temps will run high anyway.
Re: Thermostat Temp
Thanks for the response
944-v8- Posts : 59
Re: Thermostat Temp
LS1 motor - I have a 165' t-stat, an all aluminum radiator that is basically a stock replacement, Porsche fans, computer set to run fans on 200(low). in 85-90' weather I run 195 on cooler days down highway it runs cooler than that.
gdopnt- Posts : 127
Re: Thermostat Temp
Thanks Gdopnt: I have an AL radiator from Evans and the Porsche fans as well. I'm going with the Hi Flow 165 deg stat. I'll probably set ECU for 200(low) as well.
944-v8- Posts : 59
Re: Thermostat Temp
Thanks gdopnt: That's great info.
944-v8- Posts : 59
Re: Thermostat Temp
Stock 96 Vette LT fan settings are:
low speed fans ON at 104°C (219°F) and OFF at 98°C (207°F)
high speed fans ON at 109°C (228°F) and OFF at 103°C (214°F)
IIRC the stock thermostat temp is 180. If you go with a lower temp thermostat, lower the fan settings to match.
The 96 has dual fans that are both running for either low or high speed operation.
Re: Thermostat Temp
Erm....i'm running a 165* T-stat, stock 87 944na radiator, stock cooling fans. Didn't touch a damn thing and she sits perfectly at 190* using stock cooling fan triggers etc.
v8944- Posts : 211
