PSA!! I found a VDO Temp Sending Unit with LS Threads!
+6
Slpr948
matt889
scryfst
erioshi
v8944
10 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Hey guys,
Just got off the phone with a VDO Tech Service Rep...he actually called me back after our initial conversation to let me know that VDO makes a LS1 specific Temperature Sending Unit with a 250F temp range!
Ohm range is 287.4 - 22.7 ohms (the same as the 323-095 sending unit everyone uses with adapters), Ohm's at 190F (~88C) is 51.3, which falls nicely on the plot chart.
This sender may be a couple of degrees off, but doesn't require any adapters, drilling and tapping or anything like that
Part Number: A2C59517248-S
Available from Summit Racing, Jegs etc for right around $20!
I'm going to be ordering one shortly, and will be the guinea pig when I put my engine in!
Ethan
Ethan
v8944- Posts : 211
Re: PSA!! I found a VDO Temp Sending Unit with LS Threads!
Awesome! Thanks for the great info.
Agreed! Thanks for figuring this out.Rich L. wrote:Awesome! Thanks for the great info.
erioshi- Posts : 227
Great find Blue!
Thx for sharing, this will save some time.
is this tested good ? or testing waters ?
matt889- Posts : 214
No problem guys! I knew there had to be a solution out there somewhere!
Hey Matt, this is not tested and 100% sure yet. All I know is what the VDO Rep told me: that this is a LS swap specific sending unit, made to thread into the LS blocks and hook up to cars using VDO gauges with a 250F range.
I have one on order, and will report back with my findings to make this a 100% sure deal. Until then, if someone wants to spring 20 bucks and beat me to it feel free, I won't mind ;-)
Cheers guys!
Ethan
matt889 wrote:is this tested good ? or testing waters ?
Cheers guys!
Ethan
v8944- Posts : 211
That is great, thanks for sharing... look forward to hearing how it works, sounds like its in the bag though!
Slpr948- Posts : 55
Quick Update
Temp sender threads in perfectly. Don't have the ability to test function yet but I'm getting there
v8944- Posts : 211
Did it all work out? Placed my order ird 1month away from summit
bluehellfire666 wrote:Temp sender threads in perfectly. Don't have the ability to test function yet but I'm getting there
Haven't had a chance to fire the engine up yet...getting close to getting it running, just finished my wiring harness yesterday, but I've basically been stuck inside for the last 3 weeks while it rains constantly here. Update soon!
Ethan
Ethan
v8944- Posts : 211
Any updates for it working? I ordered one and I'm still waiting for it (q:9-1month summit racing) can the oem one from the ls1 be used while I'm waiting for my sensor?
bluehellfire666 wrote:Haven't had a chance to fire the engine up yet...getting close to getting it running, just finished my wiring harness yesterday, but I've basically been stuck inside for the last 3 weeks while it rains constantly here. Â Update soon!
Ethan
Quick update on this. The sensor appears to work correctly, the gauge reads exactly where it did with the original engine...however I have some gauge issues (unrelated) that affect the temp gauge, voltmeter etc. Going to go ahead and say that this is a plug and play solution. Woop woop!
Ethan
Ethan
v8944- Posts : 211
That would have saved a lot of time an frustration. Good to hear.
Arthropraxis wrote:That would have saved a lot of time an frustration. Good to hear.
That was the point of my research! I figured there had to be a solution out there in some fashion or other that would make it easier on everybody...hopefully this is the permanent solution!
Ethan
v8944- Posts : 211
I have yet to test mine prestone will be flowing this week I hope
I bought one too. I'm probably a couple weeks to first start so I'm interested what you find!
dsrracer- Posts : 66
I believe you wire this sensor directly into the Porsche wiring if you are using the Porsche system to control the fans. In that case there is no need to wire the LS1 PCM- is that correct or am I misunderstanding something?
thanks for the sanity check.
That sensor is just a sending unit for the gauge on the dash. You use the LS ecu to control the fans.
If you still have the Porsche rad and temp sensor hooked up, you could leave as is to control the fans.
You could also run the ecu fan "hi" and "low" wires into the temp sensor wiring so the ECU controls the fans.
I do have the Porsche rad temp sensor hooked up so I think my fans will run off the Porsche system. That may or may not be the most reliable but it's easy (thoughts?).
I probably wasn't clear in trying to verify that the ls1 pcm does not use the cooling temp for tuning in any way does it?
Ya, the ls ecu needs a cooling temp sensor. You'll have two sensors one for the gauge and one for the ecu
Thanks, that makes sense. There is a plug at the back of the passenger side head- is that a good location for the other sensor? This seems pretty elementary but I honestly hadn't seen it it this clearly, thanks again!
I understand the sensor issue now, thanks for the help- knowing that there needs to be two, the advanced search shows what people have been doing. Before I knew it I was just searching the general topic ( using advanced search) and most were focused on one ( probably assuming the other).
I'm getting closer now.
I never knew this to be an issue. I've had that sender in my car for years.
zeusrotty- Posts : 444
dsrracer, I use the stock 944 system to run the fans. the Porsche thermo switch is prone to failure so a lot of people remove it and run the fans from the LS1 PCM. but no problems on my car yet. and yes, two temp senders, one in each head, for the LS1 PCM and the 944 dash.
Page 1 of 2 • 1, 2
» Oil Pressure sender adapter
» Coolant temp gauge...
» Can I use a Fuel Level Sending Unit For 944 in a 1978 924
Page 1 of 2
