Today at 5:01 pm by Murrdog9000
» Team Moroney's LS1 944 Swap, In memory of Kyle Moroney.
Today at 7:16 am by bikerdude
Today at 3:33 am by Flashy2003
» ecotec swap
Today at 1:13 am by sharkey
» The famous Hydroboost issues....
Today at 12:30 am by C4924S
» Tachometer Issues
Yesterday at 11:22 pm by 948
» 83' Porsche 944 LM7 Build
Yesterday at 8:12 am by Jchard944
Tue Apr 17, 2018 6:44 pm by superman22x
» Hydroboost problems
Tue Apr 17, 2018 2:35 pm by Hotrodz of Dallas
» WTB: 944 Turbo Roller
Mon Apr 16, 2018 1:29 pm by knight76
April 2018
30
993 TT Brembo Brakes with rear 951 Brembo
Post  ghostcloak on Fri Oct 09, 2009 9:31 pm
Front brakes are 993 Turbo rotors and 4 piston Brembo calipers. The rears are 951 rotors and 4 piston Brembo calipers. Both front rotors measure 322mm x 31mm. Both rear rotors measure 299mm x 24mm. Adapters, hubs, and rotor hats are included to accommodate '87-'95 944/951/968 Porsches. The rear pads are almost new, however, the front pads should be replaced. Overall good condition with some minor cosmetic blemishes on the calipers. The front passenger caliper has some clear coat peeling, as noted in the picture below. The rotors are in good shape with only minor surface rust. They should clean up when braking a few times after installation.
Front 993TT Rotors
Driver's 993TT Rotor
Passenger's 993TT Rotor
Rear 951 Rotors
Driver's 951 Rotor
Passenger's 951 Rotor
Caliper Set
Driver's 933TT Caliper
Passenger's 933TT Caliper
Driver's Rear Brembo
Passenger's Rear Brembo
ghostcloak
993 brakes
Post  Max Energy on Sun Oct 11, 2009 8:10 pm
How much are you asking for the complete brake set up?
Email me.
Max 225 573-0774
Max Energy
Re: 993 TT Brembo Brakes with rear 951 Brembo
Post  ghostcloak on Mon Oct 12, 2009 8:48 am
^Email sent.
ghostcloak
Post  gamman on Wed Jan 13, 2010 6:32 am
still available?
gamman
Post  ghostcloak on Wed Jan 13, 2010 6:35 am
Yes.
ghostcloak
Post  ghostcloak on Fri Feb 19, 2010 4:23 am
Still available...
ghostcloak
