Yesterday at 8:00 pm by Luke714
Yesterday at 12:23 pm by chrenan
» What dipstick??
Sat Jun 23, 2018 4:54 pm by chrenan
Sat Jun 23, 2018 8:28 am by rawr
Fri Jun 22, 2018 10:25 am by superman22x
» Hello, Gentlemen.
» WTB: 944 Turbo Roller
June 2018
AGR / 083D Trans questions
Post  GarethW on Tue Jul 28, 2015 1:15 pm
Hello all,
According to the VIN and options data I had, my 1985.5 n/a 944 was supposed to have a 5S / 016K 5-speed transmission, so I had been on the lookout for a turbo transmission to upgrade, and have already purchased a transmission reinforcement plate.  However, when I pulled the transmission from the car, I find that the previous owner had been generous, and swapped in an AGR / 083D trans with LSD from the 1987 944S.
In my searches I have not been able to find a great deal about this AGR transmission, and I know that most people say the AOR from the Turbo S is the one to go for.
I'm building a 5.3 liter engine for use as a daily driver, with the occasional parking lot cone-dodging, so it's not planned to be a real fire-breather.
Does the AGR have the strengthening improvements that the Turbo transmissions got?  Does my search for a turbo trans need to continue?
Thanks in advance,
Gareth
GarethW
Re: AGR / 083D Trans questions
Post  Rich L. on Sun Aug 02, 2015 11:52 am
The AOR is the only one with the hardened gears. Only the Turbo S came with that trans. My stock 5P held up fine top 2 years of track use without that stiffening plate. I just stayed out of the power in the low gears.
http://www.clarks-garage.com/shop-manual/trans-04.htm
HTH,
Post  Sterling Doc on Thu Aug 06, 2015 5:16 pm
The AGR is between the N/A, and turbo trans in strength. For daily driving behind a 5.3 it's reasonable, and the price is right. Probably the biggest issue is that you'll find the gearing very short, and no LSD.
Sterling Doc
Post  GarethW on Sat Aug 08, 2015 1:14 pm
Thanks for the replies, I'm feeling OK with keeping this transmission, although I will see about finding a 37:27 5th gear swap for lower RPM on the highway at some point. I'll be pulling it apart when I do the reinforcement plate, so that will be a good time to do it.
Thanks again,
-Gareth
GarethW
