March 2019
Proportioning valve
Proportioning valve
Post  jpkinerk on Sun Jul 12, 2015 6:48 pm
So the car is almost sorted and I'm looking for my first track day Aug. 1st at Putnam! Last thing to address is the brake bias. Currently I'm running a 5/18 proportioning valve, but it's still trying to lock up the front brakes under hard braking. Should I try a 5/33?
I'm running turbo calipers in the rear, and LS430 in the front with BMW hydroboost.
jpkinerk
jpkinerk
Re: Proportioning valve
Post  Rich L. on Mon Jul 13, 2015 10:31 am
Well, locking the front first is what you want. But 5/33 is the next step so trying it would be good. But if it wants to lock the rears then, you've gone to far.
For myself, I tried the 5/45 and it locked the rears. Then I tried the 5/33 and it was good, locking the fronts first. This was with m030 brakes and the stock 944 master cylinder. I've since gone to dual masters with a balance bar.
Post  jpkinerk on Mon Jul 13, 2015 3:55 pm
Thanks, Rich. And you're right, I'd definitely rather have the fronts locking up than the rears. I guess it just seemed like they were locking up just a little too soon. Or perhaps i just don't have an aggressive enough tire. My research indicated it might be worth trying the 5/33 as well, so that is helpful.
Cheers,
JP
jpkinerk
jpkinerk
Post  Rich L. on Mon Jul 13, 2015 4:19 pm
Yeah, you should be able to feel the rear hunker down under braking. If you car is nose diving and not really stopping yet when a front locks, definitely try the 5/33. I've also gone to a square setup, same size front tire as rear, to get more front grip.
Post  jpkinerk on Mon Jul 13, 2015 8:27 pm
Awesome. That's good to know, I wasn't sure what the characteristics of the car should be under that hard of braking. I've wheeled some fast cars, but I'm new to the track. +1 on the square setup though, I'm running 255's all the way around.
Thanks again. Now to hunt down a 5/33.
jpkinerk
jpkinerk
Post  jpkinerk on Wed Aug 26, 2015 8:19 pm
OK. So I swapped out the 5/18 for a 5/33 and it's definitely better, however, when I give the brakes a good tap heading into a tight turn, I'm still locking the fronts. Obviously, I'm not totally standing on them since I don't have ABS, but they still feel like they're locking pre-maturely.
Should I go up yet another size with my proportioning valve? Perhaps just try plugging the rear line right into the master cylinder?
jpkinerk
jpkinerk
Post  jpkinerk on Sat Sep 12, 2015 9:01 pm
Bueller? Bueller?
I'm running out of ideas here. Is it maybe just the fact that i don't have ABS? They slow the car down really well, but I just feel like I should be able to step on the brakes harder than I am. I'm afraid on track when I go to stab the brakes heading into a turn that I'll just lock them up.
Shocked
jpkinerk
jpkinerk
Post  docwyte on Sat Sep 12, 2015 9:36 pm
Install a Tilton adjustable proportioning valve. I have a spare 7 position one if you want it and I think I'll have my infinitely adjustable one available soon too, once my 951 MC gets installed...
Post  jpkinerk on Sun Sep 13, 2015 8:48 pm
Thanks, doc. I'll definitely take you up on that. PM me with details and I'll paypal you. With that I can also hopefully diagnose if perhaps there's something wrong with my rear calipers.
jpkinerk
jpkinerk
