How to Remove Splined Shaft EmptyYesterday at 11:51 am by geegeesbits@gmail.com
How to Remove Splined Shaft EmptyMon Jan 27, 2020 2:27 pm by Porsche951toLS3
How to Remove Splined Shaft EmptySun Jan 26, 2020 4:51 pm by j7wolfe
How to Remove Splined Shaft EmptySat Jan 25, 2020 6:42 pm by kevin924kevin
» Pedal Assembly - Which one?
How to Remove Splined Shaft EmptyTue Jan 21, 2020 5:27 pm by Hotrodz of Dallas
How to Remove Splined Shaft EmptySat Jan 18, 2020 7:15 am by Rothaus
How to Remove Splined Shaft EmptyThu Jan 16, 2020 6:51 am by 87944turbo
» 82 924 with AUX Audi V8.
How to Remove Splined Shaft EmptyThu Jan 16, 2020 2:11 am by Golten1986
How to Remove Splined Shaft EmptyTue Jan 14, 2020 2:48 pm by Gumby
How to Remove Splined Shaft EmptyTue Jan 14, 2020 6:43 am by 87944turbo
January 2020
6789101112
13141516171819
20212223242526
2728293031
How to Remove Splined Shaft Empty How to Remove Splined Shaft
Post  mred2nice on Sat Jun 20, 2015 9:20 pm
Good Day Everyone
It has been some time, but I am going to get back to my 944 project and need a little help.
Next I need to get the splined shaft out of the way so I can put my motor in. I cannot find the document I had that detailed what I need to do back by the transaxle so I can pull the shaft back through the tube.
Can you help out with some advice?
Ed
mred2nice
How to Remove Splined Shaft Empty Re: How to Remove Splined Shaft
Post  944-LT1 on Sat Jun 20, 2015 9:27 pm
I'm a bit confused. You want to remove the shaft from the torque tube? I'm not sure why you'd want or have to do that.
Question
Anyway, the only way I see to do something close to what youre saying is to remove the 2 allen bolts of the clamping sleeve that joins the torque tube shaft to the transmission input shaft and slide the sleeve towards the transmission. There may be an inch to be had but then again you might as well remove the transmission at that point.
Post  mred2nice on Sun Jun 21, 2015 10:37 am
Hello...thanks for replying.
I just want to slide it back so I can drop the motor in. Isn't there some kind of pod on the back of the transaxle I need to remove? I had a real nice step by step write up but I can't find it.
Ed
mred2nice
Post  bluehellfire666 on Tue Jun 23, 2015 4:27 pm
With the radiator out you should be able to get the engine in without moving the torque tube/driveshaft at all...i've done it several times with my LT1. You have to remove the front end accessories and the crank pulley and it has to go in caddy-cornered to the engine bay until you get it below the hood latch to pull it forward and straighten it out.
bluehellfire666
bluehellfire666
Post  mred2nice on Tue Jun 23, 2015 10:03 pm
Good idea!
I was going to build a removable Radiator pod up front. The one I have is a really large griffin with 2 electric fans.
Ed
mred2nice
