Those of you who have tuned out the VSS (Question)
So, my current plan is to tune out the VSS sensor which doesn't seem to be much of an issue anymore.
However, I am using a Red/Blue 5.3 harness/computer and was wondering if I can get away with just removing all the VSS/Auto Trans bullshit or if there is some reason for which I might need to keep it?
Fishey
Fishey
Fishey- Posts : 1
Re: Those of you who have tuned out the VSS (Question)
Here's some posts to go thru. I would keep it if your car is a street car.
There are several posts here that discuss the VSS, search a little, as suggested by spence, and you may find an answer to your primary question.
The driveability of my car is much better with the VSS, supposedly power can be negatively affected by not having the VSS....at least on the LT1s
