Bad fan relay?
Bad fan relay?
So I've been working on diagnosing a passagner side fan no turning on. I was about to replace the fan resistors under the dash, but went through all the easy stuff first; relays, fuses, etc. I noticed when I'd tap on the fan relay, the fan would kick on. Naturally I thought it was a bad relay so I swapped it out for a spare I had, however, I was able to repeat the issue with the spare relay. Could both relays really be bad? Seemed unlikely to me.
Any ideas are much appreciated.
jpkinerk- Posts : 174
Re: Bad fan relay?
Unlikely but very possible.
I'm guessing your car is an 1985.5+ but regardless, Id check the connectors/wiring under the fuse block. May be a corroded or damaged wire or connector. Check the original relay for any corrosion on the terminals.
I believe that relay is the furthest back in the block and right where any moisture would contact first as run-off from the windshield and wiper cover.
Re: Bad fan relay?
The original relay was pretty corroded. I kept my backup relay (with clean terminals) in the car and double checked the fuses. Went ahead and let the car idle for a while until the fans kicked on. In doing this, I discovered that it's only the low speed on fan #2 that isn't working. High speed kicks on just fine without tapping the relay. However, when both fans should be running low speed, I still have to tap on the relay to get fan #2 to engage low speed. Could this be a resistor? I guess I just ruled it out because of the tapping on the relay symptom.
Yesterday at 9:56 am by ndog52
