Exhaust alternative?
+3
7 posters
I mocked up a log type manifold just to see what it would take. It would be perfect for stock motor type builds.
manifold
Admin, that looks really good, what size pipe u using, maybe alittle ceramic and bingo. cost?
kevin924kevin- Posts : 927
Re: Exhaust alternative?
No cost just yet , Still in the Prototype stages. Defiantly coated before shipping! It is 2.5" mandrel bent tube on the large pipe and 1 3/4" on the smaller tubes. I'm thinking of doing a V band clamp or some sort of ball connector for the collector mounts. Hope to make the pretty cheap. It'll probably cost more to coat them than to make them!
maniflods
Keep us posted. Thanks.
Those are nice.
Excellent. 1200* ceramic spray paint and call it a day. Done a few bikes that way and it never burned off.
Looks GREAT!
the951racer- Posts : 135
These probably work on many different applications other than the 944.
x2944-LT1 wrote:These probablywork on m any different applications other than the 944.
matt889- Posts : 214
