» Dual MC Mounting Bracket
Yesterday at 8:11 pm by 87944turbo
Yesterday at 7:50 pm by hp18racer
Yesterday at 5:20 pm by dougr944
» Need help! Car won’t start
Yesterday at 3:51 pm by jess2suityou
Yesterday at 9:44 am by keetle
» Brand new ls3 build
Yesterday at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Yesterday at 1:35 am by Porsche951toLS3
January 2019
78910111213
14151617181920
21222324252627
28293031
Stubs units for T56
Stubs units for T56
Post  kevin924kevin on Mon Apr 20, 2015 10:37 am
Rob, would you consider making the output units from the T56 to mate with my CVs?
Re: Stubs units for T56
Post  xschop on Tue Apr 21, 2015 1:08 pm
I already explained there is a company that makes T56 output shaft to 930 CV conversion.....
IT is UNNECESSARY but The Driveshaft Shop carries them....
Part# 108-GM-I-42
ALL YOU NEED IS A type 2 CV to 930 CV adapter for your outer stub shafts.
Then all you do is figure how long your 930 aftermarket axle needs to be to insert into the FACTORY C5 output tri-lobe. It is 28 spline and matches a 930 axle spline. The inner race from the tri-lobe is exactly 31mm wide, so I cut a 31.2mm width between the CV clips. I've done 8 sets of 930 axles this way for the 928 6 speed conversion including the Enigma V12 and Just Peachy's LS3 Z06 swap with over 500hp.....
Someone on GT40 site was already making the CV adapters at one time, but I cannot find them, so I'm making my own. I can make an extra pair for you if you'd like....
Cvs
Post  kevin924kevin on Thu Apr 23, 2015 8:07 am
Rob, i will take a set please PM me with cost and paypal info. Thank you.
Post  xschop on Tue Apr 28, 2015 5:56 pm
I will start these next week. The print had called for 1045 IIRC, but I can't get that in a small piece locally, so I'm going to make them from 4140. So about $200/pr
Stubs
Post  kevin924kevin on Wed Apr 29, 2015 2:15 pm
Rob, please send me paypal link.
Post  xschop on Wed Apr 29, 2015 3:04 pm
Sent PM.Luckily I found 1045 in a short piece, so I'm going with the print spec.
If anyone else wants a set, I'll make them for $225 pair and you can send me 930 axles and I'll cut grooves for $50 and send back.
On the 944-Vette trans swap, they will be somewhere around 17- 19" so measure 3x then order.
Post  xschop on Sun May 17, 2015 4:45 pm
I'm finishing the lathe work and will drill/tap next.....
stubs
Post  kevin924kevin on Sun May 17, 2015 7:42 pm
Rob,they look good, just another fine product from you.
Post  xschop on Sun May 17, 2015 9:15 pm
I should be shipping yours Thursday Kevin. You will have to determine the exact length socket heads to use for m8 x 1.25 bolts going into 944 stub shafts....
Post  xschop on Wed May 27, 2015 12:26 pm
As a side note, these particular adapters don't work on ABS hubs. There needs to be another 1/2" or so material added to the thickness were they bolt on to the stub shafts as the ABS ring has a smaller ID....
Stubs
Post  kevin924kevin on Thu May 28, 2015 10:11 am
Rob, so i will have to change my stub units as they have the ABS ring. I figure a basic turbo unit will work.
Post  xschop on Thu May 28, 2015 1:34 pm
I had an early alloy arm without the ABS ring on the stub shaft and the adapters bolted right up. I have on hand an 87 arm with ABS ring and you can just cut it off if you're not running ABS....
Stubs
Post  kevin924kevin on Thu May 28, 2015 1:42 pm
Rob, thanks, thats what i will do.
Stubs
Post  kevin924kevin on Wed Jun 03, 2015 7:32 am
Rob, the adapters landed, Very nice product. Thank you.
Post  Slpr948 on Sat Aug 15, 2015 4:20 pm
Ive been MIA for a while, just saw these... they look like a great solid piece!
I designed my own over the last few months for my ABS hubs and they look pretty damn similar to these. I made several versions with Inventor, then 3D printed full size pieces to test fit until I was happy with it. Slight changes may still need to be made, but overall it appears it will do the job.
The pictures arent the best... but I will post better ones once they are made in steel. The orange piece is a 3D printed 930 CV I used for mock fitting. Blue is the adapter...
Slpr948
