» alignment specs
Today at 12:53 am by sharkey
Yesterday at 9:46 am by JSP
» Transaxle rebuild
» Tpc LS adapter plate
Ls2 with standard 951s transmission?
Post  pa951 on Wed Mar 11, 2015 12:56 pm
Would a standard 951s gearbox with lsd be able to handle the ls2 power? 400hp and 400lb torque?
Or should i have extra's added for strength?
pa951
Re: Ls2 with standard 951s transmission?
Post  99sierra4x4 on Wed Mar 11, 2015 8:09 pm
I would think it will be fine. Many people run the 951 Tranny with no issues.
Andy
99sierra4x4
Post  Rich L. on Wed Mar 11, 2015 9:28 pm
My LS1 makes 438hp 399lbft. AOR trans. LSD working great for 2 track seasons now.
Post  docwyte on Thu Mar 12, 2015 9:37 am
My 383 stroker LSx makes over 500hp and 500ft lbs. No issues with the stock AOR, 5 track seasons.
Post  jws on Thu Mar 12, 2015 12:40 pm
Docwyte, your car sounds fast!!!!
jws
Post  pa951 on Fri Mar 13, 2015 5:39 am
Just would not want the cv or transmission to blow up on the first burnout i accidentally make Rolling Eyes
Will make a solid mount from gearbox to chassis on driverside. That should help somewhat i guess?
And getting the na fifth gear installed. For cruising the highway.
pa951
Post  Rich L. on Fri Mar 13, 2015 11:02 am
Doc, he's asking about trans longevity. You have not put 500hp through your trans for 5 seasons. You were at what, 400 rwhp for the last 2 seasons? And wasn't it the stock turbo motor before that?
And for "accidental burnouts"... it'll be CVs that you shred doing that.
Post  docwyte on Fri Mar 13, 2015 12:27 pm
Car had 375rwhp for 2 years, then 400rwhp for two more years than 425rwhp/410ft lbs for another year.
So five years total on the AOR, with 450-500+hp, no transmission issues. Plenty of other stuff breaking tho
Post  Rich L. on Fri Mar 13, 2015 2:10 pm
Right on. Good test of the AOR. What do you run for axles? Any trouble? I blew up my original 944 axles and switched to VW van axles with type2 joints and it's been solid. Seems to be all about getting the bolts in there clean and tight.
Post  docwyte on Fri Mar 13, 2015 2:14 pm
Oem, original Turbo S axles. Never had an issue with them.
Post  Arthropraxis on Fri Mar 13, 2015 7:51 pm
If you drive it like an idiot you will blow the transmission. A friend drove my car and spun the fixed third gear on the shaft. The failure could be blamed on a 135K transaxle or his aggressive shifting technique. In his defense, he won a GT1 SCCA championship and knows what he is doing but shifts everything like they have straight cut gears.
Post  pa951 on Sat Mar 14, 2015 3:08 am
There is a difference between driving like an idiot and a bit of playing Cool perhaps i'm to scared. I only want to be able to make a good sometimes smoky start. And a good drive on the autobahn playing with its brothers and sisters.
pa951
Post  Techno Duck on Sat Mar 14, 2015 8:27 am
I think the most important thing is that you roll on the throttle, it just cant handle shock loads like a T56! Hard standing starts is what will really kill the transmission and your CV joints quickly.
Post  docwyte on Sun Mar 15, 2015 9:16 pm
My car spins the tires so easily the axles don't really get much of a work out
Post  pa951 on Mon Mar 16, 2015 2:08 pm
I will be getting the na fifth gear installed. What rpm can i expect to get driving in fifth gear 90/95mph?
pa951
Post  docwyte on Mon Mar 16, 2015 2:52 pm
Dunno. I don't cruise at 90-95mph. At 80mph I'm seeing just about 3000rpm with the NA fifth gear swap.
