» Passenger footwell
Wed Dec 12, 2018 1:41 pm by Porsche951toLS3
» 85.5 944 LS Adventure
Wed Dec 12, 2018 12:55 pm by ryan08
Tue Dec 11, 2018 10:09 pm by sharkey
» Problem with Dual Remote Vacuum Boosters
Tue Dec 11, 2018 12:37 am by Porsche951toLS3
» 1984 Tach wire
Mon Dec 10, 2018 10:54 am by Rich L.
» 1984 944 Tach and Temp wire color
Sun Dec 09, 2018 1:58 pm by Punisher948
Sat Dec 08, 2018 9:03 pm by robschwieb
» LS Parts for sale
Thu Dec 06, 2018 10:04 pm by Porsche951toLS3
» Dual headlight motor conversion
Wed Dec 05, 2018 8:39 am by 948
» WTB - LS Conversion Oil Pan & Pickup
Mon Dec 03, 2018 10:21 am by cazbah362
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
How to finish the bonnet off?
Post  quarterflash on Fri Mar 06, 2015 11:53 am
Hi Guys
I have modified the bonnet to clear my LT1 engine but how should i blend it in with the badge panel and lights. The lights will be twin static from Vintage Exotics. All suggestions gratefully received.
Q
See the lights here [You must be registered and logged in to see this image.]
and the bonnet mod here
and here
quarterflash
http://porschevy.co.uk/
Re: How to finish the bonnet off?
Post  vundba on Tue Mar 10, 2015 8:52 pm
Did you buy it that way or did you modify it? At first I thought you put the hood on backwards.
Hard to say how to blend it because it cuts off so abruptly,maybe if you tapered it back on an angle.
vundba
Post  quarterflash on Wed Mar 11, 2015 11:45 am
Hi Vundba
No it is a standard fiberglass bonnet that we have modified.
We had to add the increased height because of the intake elbow etc that is at the front of the engine. I don't know how other hybrid owners manage to get the bonnet shut without modification. I have removed the pop-up lights and their actuation system and the bonnet latch.
We are thinking at the moment to add an additional modified badge panel that blends the current badge panel in with the new bonnet perhaps to also include an air intake.
Q
quarterflash
Post  vundba on Wed Mar 11, 2015 6:58 pm
I've got an Lt1 with a GM lt4 head kit and a BBK throttle body ,I put a rubber elbow and a Spectre cone shape air filter .I also removed the hood latch assembly and use hood pins but my hood clearance is atleast 1/2 to 3/4 of an inch.If your intake is standard then your engine is sitting to high.I would post a picture but it's to much of a pain in the *ss on this site .
vundba
Post  bluehellfire666 on Wed Dec 30, 2015 2:14 pm
Like this, with a 4 inch intake it fits without issue. What is hitting on your engine?
bluehellfire666
Post  docwyte on Wed Dec 30, 2015 3:28 pm
You're going to need a custom header panel to blend that.
I echo the statement that it looks like you've got it backwards. At least here in the US, cowl induction hoods point the opposite direction.
Check out IFC Racing, they have a very nice cowl induction hood made specifically for LS swapped 944's.
