Sources for dual MC brackets
Hi,
I'm relatively new to the forum - great information being exchanged. Have been looking for resources for setting up dual MC - namely the bracket and hardware.
Spoke with Kokeln (I'm using their hats & caliper adapters) and they still have a couple of their dual MC setups in stock - but their solution requires additional modifications that I'm not sure I want to deal with.
Can anyone recommend an alternative resource for a complete dual MC bracket setup?
Thank you in advance,
Dan.
Dan.
Dan J- Posts : 117
Re: Sources for dual MC brackets
Xchop was making a mount, you could contact him to see if he still is making them. I found this on the net, not sure if it would work. http://www.gorillaperformance.com/
yea pm xschop, he will work with you
modenas- Posts : 285
Thank you for the suggestions.
Seems there are two routes to take: Dual MCs or Wilwood single MC.
I've also searched for information on the Wilwood 260-7563 setup. Seems like one option is to use this MC plus a bias adjuster.
I currently have the 944v8 firewall reinforcement plate but do not have the MC conversion plate and pushrod. Also, a dual MC bracket has been on order since March, but it's not clear when that will arrive and I have to move forward with the project.
Current brake setup I'm running is is big reds in the front and 951 rear calipers.
Can anyone here recommend one solution or the other based on experience? The goal is decent pedal feel with some front/rear adjust-ability. Also, simplicity is a good thing because I don't have any fabrication skills.
Thank you,
Dan.
Thank you,
Dan.
Dan J- Posts : 117
I have a Wilwood master cylinder setup wit a summit racing adjustable proportioning valve that I am taking off of my car to install the hydro boost. I want to sell it, make me a reasonable offer and it's yours. It only has about 500 miles on the setup. Can post pictures later.
Cool - I'll send you an email.
Dan.
Dan.
Dan J- Posts : 117
I am going to build 2 more of the all alloy housings next week. I have to make a small revision for the Tilton Dual MC bracket that is now being sold since it is different from the 72-650.
FYI....The total cost of dual MCs is around $550 all done and pinned down. So if on a budget and a single MC will fit the bill with stock brakes... then go that route....
Thank you for your reply - you have a PM.
Dan.
Dan.
Dan J- Posts : 117
What kind of revision needs to be done? Will the wilwood mount still work with it?
Yes the Wilwood 340-4630 Dual MC housing is a 60* like the discontinued Tilton 72-650, whereas the Tilton 72-610 is 90* and the side MC bolt has a protruding casting there that the 72-650 did not. I am going to mill off the end there On the housing I designed so the less expensive 72-610 will bolt right up....
