Quick question
Quick question
Went to start up today for the first time, cranked but no fire...
did hear the fuel pumps at first ignition turn, checked electrical connections (spades and studs are different sizes so it's pretty hard to mess these up)
checked a spark plug - dry
so here are the connections below - I have these reverse right?? Looks like the smaller centre connection is supposed to be the return and the larger outer connection is the feed in looking at other posts...
TIA Stu
TIA Stu
leadfoot- Posts : 22
Re: Quick question
Never mind, changed them over and it fired right up
S.
S.
