Long, Short and intermediate 5th Gears ...... Trade?
+3
zeusrotty
hickmaster2001
johntorg
7 posters
I have several Long 37:27 (0.7297) and Intermediate 36:28 (0.778) 5th gear sets which I would like to trade for Short 35:29 (0.829) 5th gear sets from 944 Turbo Transmissions. Is anyone interested?
johntorg- Posts : 69
Re: Long, Short and intermediate 5th Gears ...... Trade?
I am interested. My box is at the builder now and could have the gears shipped when I get them back. Email me at [You must be registered and logged in to see this link.] if you still have these. Thanks!
hickmaster2001- Posts : 57
I need a short because mine is long and my car is more of a track whore.
zeusrotty- Posts : 444
5th gears
zeusrotty wrote:I need a short because mine is long and my car is more of a track whore.
I also need a short 5th so looking for someone who needs a long one.
I would like to trade my short gear from my 5P turbo trans for a long gear. Anyone still interested in the short gear?
FrostedFlakeJake- Posts : 263
Okie dokie. Let me work on getting it out then. Didn't want to start down the road unless someone was sure. I should have it ready to go this weekend.
Swap
No Problem. I also have to pull mine. The best way will be to include the Syncro, I will do the same.
swap
In addition to the .7297 5th gear, I have a .778 5th from a 944S2.
John,
Sorry but I'm going to back out of the trade. I didn't realize the short gear set I have was actually worth any $$$.
Hate to do that to you but I need all the extra cash I can get with this project. Best of luck to you
No problem I was just going to use it to build a spare trans. for my race car.
Need some help! Found someone to do a trade+cash for my short gears. This is the photo of his long gears... Question is should I be concerned about the notch that are in every teeth of both gearsets? Thanks guys
the notch is machined into the gear before its hardened. its supposed to be there
Okay that's kinda what I thought. I was just worried because I saw other photos that had the slot in different locations on the gears.
typically they put them there for identifying them. in different transmissions ive seen some with 1 2 or even 3 marks, and in different places on the gears. often its for different ratios, but can also be for gears of the same ratio that have a different tooth angle.
Has anyone had extreme resistance pulling off the fixed 5th gear? I got mine to move a couple MM before it broke my first gear puller. I wasn't surprised since the jaws were very skinny cast items. But then last night I spend an hour or so modifying a new puller to make the jaws fit and the gear has so much resistance coming off the spline that it bent the threaded portion of the puller!
I don't know what the heck is going on!
I have had a few 5th gears give me trouble coming off. Most of the time, no dofficulty, but I remember one that was much tougher. I was parting a bunch of gear boxes I had accumulated over the years and thought it strange that most came apart easily but one did not. I think I broke out the propane torch, while the puller was already under tension, heated the gear, then applied more pressure with puller and gear finally slid off. I also used a very beefy SnapOn puller.
phlip- Posts : 67
yup! heat was my savior last night. same exact process. But i'd be darned if it didn't fight me till the very end.
bringing this back from the dead, wondering if anyone has a short or intermediate 5th gear set around. im looking at purchasing a turbo s box that already has the long 5th gear swap done, and with my swap the short gear set would be better.
I've got a short 5th gear from my old Turbo S AOR gearbox for sale...
» VSS Sensor brackets and gears
» FOR SALE/TRADE 1987 944 TURBO (& 1983 944 PARTS CAR) 350 SBC SWAP PROJECT - $5.5K OBO OR TRADE
» 16" wheels for sale/trade
