trans weight
trans weight
Does anyone have a turbo trans that they could scale. I am going to check my T56 but need a reference to base my shock package on. Thanks.
kevin924kevin- Posts : 927
Re: trans weight
I don't have mine out currently, but recently did, and the conversation about weight came up. I was told a turbo trans with cooler weights 140 lbs. However, I didn't see it on a scale with my own two eyes, so take that for what it's worth. Having lifted it myself though, it sure felt like that was a pretty close figure.
I'll have my trans back out though in the next few weeks, so if you don't have a definitive asnwer by then, I'd be happy to throw it on the scale and report back.
Best of luck.
JP
Best of luck.
JP
jpkinerk- Posts : 174
trans weight
Thank you for the response. It would be appreciated. I am trying to sort out the spring weight for the rear with the T56 trans. My car was a 24 and i never thought about weighing the snail before i got rid of it.
Re: trans weight
944 trans is 120-140 range depending on model and cooler.
924 snailshell is lighter, closer to 100lbs.
v2rocket- Posts : 121
