fade on brakes setup Q's
Who has actually got fade on a brake setup?
If so, which pads and tires were you running?
What % of the pads and tires were left?
My experience says that proper pads appropriate for racing temps will eliminate a lot of issues with brakes. IE: hawk/stock pads are not race pads.
Last edited by gamman on Wed Jan 13, 2010 11:56 am; edited 1 time in total (Reason for editing : removed word)
gamman- Posts : 112
Re: fade on brakes setup Q's
On the street? Never. No one should have either....
944-LT1 wrote:On the street? Never. No one should have either....
Mine fade when cold, but thats because they are Ceramic type pads and don't bite until they are hot. When at operating temp, there is never ANY fade.
Dawgz83948- Posts : 603
that's not really the definition of fade though.... Isn't fade when the pads overheat and actually liquify/gasify a tiny layer of the pads that keeps them from contacting the rotors? You just have pads that aren't up to temp yet, not really the same thing. Just not ideal for street setup.
Luke714- Posts : 441
