oil pan interferes with crossmember when pulling engine from top
As I look at my oilpan, it looks like it will hit my crossmember before I am able to slide it far enough forward to disengage from the torque tube. Anybody else see this? Or do I just take the pan off before sliding the engine forward? Thanks in advance for the help.
Re: oil pan interferes with crossmember when pulling engine from top
Take the cross member off first.
Jack the car up and lower the motor with the crossmember. Same to put it back in. You will save yourself many headaches.
zeusrotty- Posts : 444
» Pulling Turbo Engine, What To Keep?
» Oil Pan interferes with pick up tube/screen
» Pulling vacuum up top, intake, exhaust or both?
