ecotec swap
+20
alex sol
577nitro
matty89
944_GASM
racertomtom
P911P951
SOB Racing
phlip
jakeb
Sirayden
erioshi
v2rocket
sparkydog
24 posters
Page 2 of 8
Page 2 of 8 • 1, 2, 3, 4, 5, 6, 7, 8
Re: ecotec swap
got the cams installed last night, and painted the engine today
got a good pile of parts to get powdercoated before i can finish assembling the engine.
Re: ecotec swap
looks awesome!
How similar an engine is this to the LSJ?
I really like the packaging on those with the supercharger. Almost enough to try to fit one...
v2rocket- Posts : 121
Re: ecotec swap
its very close to the same engine. all of the 2.0, 2.2 and 2.4l ecotecs are very much the same engines. the blower setup from the 2.0l lsj will bolt right onto a 2.2 or 2.4l. my daily driver is a cobalt ss with the lsj, it puts down 275whp and 260ft/lb. keeping the stock supercharger, thats about the limits of the stock engine on gas, some have put down 300hp with e85. there is an eaton tvs blower that bolts right up, however 330-350 is about it. now take the same stock lsj longblock, swap the blower out for a turbo, itll put down 420whp all day long. the blower makes for a real nice daily driver though, normal driving its got v6 grunt.
as for swapping an lsj with the blower into a 944, i dont think its possible. have a look at some of my early pics and were the engine sits in the car. i had to clearance the firewall around the oil filter housing, and the back of my intake manifold is almost in the firewall. the supercharger inlet is at least 2" behind that oil filter housing, the throttle body would be sharing space with your right foot lol. the lsj has been used in rwd stuff before, people have cut the end of the blower off and welded a 90 degree elbow on and redone the inlet, but because of our firewall shape in the 944, i just dont see it. tilting the engine to the passenger side could be done, however im not sure about oil drain back from the head. its common in the fwd drag engines to tilt them forward up to 25 degrees, but they run dry sumps with a valve cover scavange.
Re: ecotec swap
couldnt resist setting the turbo on it for a couple pics
Re: ecotec swap
well guys, its on the backburner again. i decided on a brake upgrade and have gathered most of that stuff (lexus ls430 calipers, wilwood 2 piece rotors with xschop rotor hats, rx7 calipers and 86 turbo rotors out back). the sema show is right around the corner, we have 2 major builds and not enough man power, so im working 16 hours a day 7 days a week again.
today we had a media company come to our shop and do a video blog live. the company (two sharks media) is heavily involved with the show Supernatural. anyways, i thought id share the video with you guys show off some of the stuff we are building. im not in the video, was to busy on the "secret project", however my 944 got some attention.
Re: ecotec swap
well sema is a couple weeks past, our 2 builds both got derailed and things are just slowing down a bit now. hoping ill have some updates soon.
a small update, i have a clutch disc on route that should work with my current spec 3+ pressure plate and fidenza flywheel. ive also got the slave cylinder that ill be using, its from a 2005-2012 mustang. all i should have to do is figure out my depth from the pressure plate to the back of the bellhousing, make a spacer/mount for the slave and it can all go together and the motor can go in the car.
Re: ecotec swap
finally some progress. ive finally got a clutch for the beast. the end result is i used the stage 3+ spec pressure plate i already had, got a spec 3+ disc for a 944 n/a, and with a few mods it all works together along with a fidenza flywheel. i also managed to work out the slave cylinder/release bearing. i used a slave cylinder from a 2005-2012 mustang, ive used them before in custom applications, they work very well because they have a lot of possible travel (actual travel is determined by the master cylinder) making them forgiving to set up. ive got the pedestal for it machined and bolted to the adapter plate.
ive also got the oil pan powder coated, so its ready to go on. all i need to do is make the steel line from the slave to outside the bellhousing and ill be ready to bolt it all together and cram the motor in for the final time.
Re: ecotec swap
its back in, and this time to stay
had to do some more machining on my slave cylinder mount. when i measured everything when it was in pieces and calculated the installed height i somehow made a .200" error and i couldnt get the adapter onto the bellhousing. woops. of well, at least it was .200" i had to remove and not add. so its in the car to stay now. hopefully with get the majority of my parts powdercoated tomorrow and can start bolting some stuff on.
Re: ecotec swap
managed to get a little more done today. turbo oil feed and returns are done, and built the hot side charge pipe.
Re: ecotec swap
and the cold side charge pipe is done, aside from a couple bungs for iat sensor and meth nozzle
and im a little happier with my welding tonight
Re: ecotec swap
That looks like a fun swap. The reliability factor alone justifies tossing the crapasil block.
Re: ecotec swap
its been a lot of fun so far
got my lower rad "hose" built tonight. managed to get it sealed with no pinholes on the first shot.
also started the downpipe tonight. it looks like there is a lot of room for it, but its real tight once you start snaking 3" tubing through there.
Re: ecotec swap
im back at it this week. my boss decided we should take the week off, so im spending the whole time working on the car.
as of now, the exhaust is complete. the turbo manifold, turbo, downpipe, exhaust and water pump cover/thermostat housing are all in for the final time. got an air intake built, all the turbo plumbing is done.
im hoping to button up most of the mechanical stuff tomorrow. ive gotta build fuel lines, mount the fan, install the rad hose, bleed the brakes and clutch, and a couple other loose ends. hoping to start wiring it by thursday.
Re: ecotec swap
starting to get down to the last things. the car is now 95% wired, just need to terminate the oil pressure sensor wiring and make a battery cable to the starter. had the car powered up for the first time, ecu, dash logger, and all the gauges worked right off the bat, not a single issue. that was one good thing about waiting for parts for so long, it gave me time to really plan out the wiring harness. as it is, only 2 wires from everything i added are spliced into the factory wiring, and thats switched power and an illumination wire for the boost gauge.
tomorrow ill be finishing the wiring, making fuel lines, and hopefully bleeding brakes and the clutch. if everything goes the way im hoping, itll run before next weekend.
Re: ecotec swap
its ready to fire. brakes and clutch are bled (although the clutch seems to lose pressure overnight, a couple pumps and its fine), everything is full of fluid. had a bit of time to i tossed an old deck in it tonight, sounds craptastic with 4x6 speakers all around. hood is back on, although i cant close it. did some trimming of the structure and its so close, i can actually get it to latch if i force it, but its on the valve cover. still not sure what im gonna do, dont really want a z28 cowl, but anything else is gonna look goofy cause its so far forward. doing a bulge would work too. just dont know.
conversion
Very nice build. Do a video when she's running.
kevin924kevin- Posts : 927
Re: ecotec swap
thanks. there will for sure be videos, we have go pro mounts around the dyno, and ill be putting one in the car lol
Re: ecotec swap
sharkey wrote:[You must be registered and logged in to see this image.]
Put one of these in the hood where the valve cover hits
phlip- Posts : 67
Re: ecotec swap
Nothing wrong with a cam cover sticking through a hood. My 4g63T swapped Rx7
SOB Racing- Posts : 22
Re: ecotec swap
phlip wrote:sharkey wrote:[You must be registered and logged in to see this image.]
I have one of these in fiberglass that I did not use if you are interested...
P911P951- Posts : 48
Re: ecotec swap
yea i dont mind that scoop, it could work. i started thinking about how close the turbo is to the hood and how much itll bake the paint. with that in mind i decided to go with something a little larger, even though i dont really want it. i ended up ordering a scoop from a 79-82 mustang. itll get the job done, and i think itll suit the car. its in transit right now, should have it next week.
havent gotten it running yet. having some issues with the computer, the tuner is working with microtech directly to get it sorted. the ecotec is a custom application for them, so this isnt really anything unexpected. being they are in australia, it takes a bit to get an answer. hope to have it running soon though. in the mean time i got my rear valance mounted on the car, so once the scoop is on the hood both can get painted at the same time.
Re: ecotec swap
didnt have a lot of time today, but we got it running. just got the fuel trimmed enough so itll fire and run. my wideband is giving me issues, and the alternator isnt charging, but it runs. gonna have to get those few things sorted before i can run it much more.
Re: ecotec swap
so turns out the alternator is dead. no biggie, ill grab another one tomorrow. still managed to run it for a while, got the idle sorted for the most part.
Re: ecotec swap
got the alternator swapped out this week, fixed the problem. i started fitting my hood scoop tonight
i decided to mount the scoop backwards to make it an extractor hood. it did look kinda cool the other way, but a little too aggressive to go with the rest of the car. i need to do some fitting to make it match the curvature of the hood, and invert the curve at the front of the scoop so it matches the front of the hood.
Re: ecotec swap
i started with contouring the scoop to fit the hood today. ended up taking more material out than i wanted, and ill have some glassing to do. then i cut the front edge of so i can reverse the curve to match the front edge of the hood. more glassing to do lol. hoping tomorrow ill have it all put back together and ready for some filler and body work next week. id like to get it and the rear valance in paint soon.
also got my new battery. went with an Xs power s925. its a small agm battery, still plenty of cranking amps though. used these in quite a few cars. also put in one of the battery trays my shop is starting to produce.
the battery holders are built to fit specific batteries and are not universal. right now we have them to fit popular xs power and optima batteries, as well as some stinger audio batteries and braile lithium batteries.
earlier in this thread i had info on the obx fuel rail that is marketed for the lsj and doesnt fit. i did make it fit, but the end result is i ended up with leaks around the o-rings. after an evening of frustration i ended up ripping the thing off and throwing it at the wall. ended up with the modified 03-05 l61 rail back on it. i went away from it because of firewall clearance, i just ended up hammer modding the firewall a bit, was my only real option.
Page 2 of 8
