March 2019
Mounting plate
Mounting plate
Post  kevin924kevin on Fri Nov 07, 2014 12:31 pm
So i have a friend at a machine shop and they are going to make my mounting plate for the firewall and hydroboost. Question, does the angle matter if it sits out from the firewall or can it be reset into the firewall space ie the factory opening. I had a file shipped to me by one of our members for the same plate everyone uses. What is the perfect angle, i think i will just duplicate my old cereal bowl angle that porsche did, our do i need any mods?
Re: Mounting plate
Post  Remy6908 on Tue Dec 23, 2014 11:50 pm
From what I've read from other topics is the angle is 12°.
Remy6908
Remy6908
plate
Post  kevin924kevin on Wed Dec 24, 2014 8:03 am
Thank you, yes i read the same just want o be sure.
body change
Post  turbobob924 on Wed Dec 24, 2014 5:22 pm
This project is very cool!
Im late to the party so sorry if I missed something on how you did the body transformation. I dont see very many pictures or that you setup a galley of pictures?
turbobob924
turbobob924
http://www.turbo924.com
Re: Mounting plate
Post  Techno Duck on Thu Dec 25, 2014 6:26 pm
Went with 12 degrees on my plate. I welded the raised portion shut once i was satisfied with the angle.
The hydroboost was probably one of the most tedius parts of my swap, i spent many hours under the dash mocking everything up. Tightening the nut on the hydroboost also was a major PITA.
Re: Mounting plate
Post  Remy6908 on Thu Dec 25, 2014 7:46 pm
Techno- looks good. Just like the one I have. The main nut does suck. If used large vise grabs to tighten mine. Just gotta make sure it's straight when you mount everything. Test fit the brake clevis before tightening to fire wall because you may have to adjust it.
Remy6908
Remy6908
Re: Mounting plate
Post  Lemming on Fri Dec 26, 2014 8:17 am
Remy6908 wrote:The main nut does suck. If used large vise grabs to tighten mine.
I ended up buying the "special tool" for the nut, makes life soooooo much easier. Found it on Ebay for $40, expensive, but a huge time saver.
Re: Mounting plate
Post  Remy6908 on Fri Dec 26, 2014 8:25 am
Fully understand. With this build I've come to realize convenience out weights expense.
Remy6908
Remy6908
plate
Post  kevin924kevin on Fri Dec 26, 2014 9:04 am
Thanks all. I will have my plate cut and bent, then fill in the opening. I will post some new pics soon.
Re: Mounting plate
Post  Techno Duck on Fri Dec 26, 2014 12:06 pm
Just googled the 'tool'... that would have saved alot of grief.
If you check out the results, the wrench type i dont think would work with the way the nut sits in the recessed section of the mounting plate (atleast on the way my mounting plate was made). Looks like another guy milled a socket which would work great. Check out this thread..
http://www.fordification.com/forum/viewtopic.php?f=5&t=15712&st=0&sk=t&sd=a
Wish i had that socket when i did mine, i used the largest pair of channel locks i have with a cheater pipe and damn near ripped my vice off the table untightening and tightening that nut.
Re: Mounting plate
Post  Remy6908 on Fri Dec 26, 2014 2:05 pm
Techno Duck wrote:Just googled the 'tool'... that would have saved alot of grief.
Lucky you with the vise I didn't even have one. Vise grips and some blood sweat and tears got that job done.
Remy6908
Remy6908
Re: Mounting plate
Post  Lemming on Sat Dec 27, 2014 8:58 am
I have the socket tool, no way to get a wrench on mine as the mounting plate has a large recess. I can remove/tighten the nut with the HB unit attached to the firewall. This is a must for my setup as there is not enough room to remove/install the HB firewall plate as one unit.
Re: Mounting plate
Post  matt889 on Wed Aug 17, 2016 8:41 am
Do you guys mounts the boost to the plate then install on the fire wall? Or mount plate to firewall then install booster ( my engine is install and I don't have much room for that) or you drop the x member and install it as a unit with the plate? I'm having a hard time under the dash to torq the booster nut.......
matt889
Re: Mounting plate
Post  Remy6908 on Wed Aug 17, 2016 8:43 am
I found it easier to mount booster to the plate first then mount to firewall
Remy6908
Remy6908
Re: Mounting plate
Post  matt889 on Wed Aug 17, 2016 8:45 am
Remy6908 wrote:I found it easier to mount booster to the plate first then mount to firewall
with ur engine install already?
matt889
Re: Mounting plate
Post  Remy6908 on Wed Aug 17, 2016 8:50 am
Ya i installed mine no problem. Easier to have a buddy hold it up while you put the nuts on from inside. Easiest way I found was to just take the driver seat out so you have room to get under the dash. Pull the carpet back as much as you can and us small rachet
Remy6908
Remy6908
Re: Mounting plate
