» Lighten clutch pedal feel?
January 2019
78910111213
14151617181920
21222324252627
28293031
928 TT dimensions
928 TT dimensions
Post  xschop on Thu Sep 24, 2009 10:35 am
I'm not sure what to think about the 928 TT's
I recently went to the Porsche graveyard and measured what I thought to be a 928 Manual TT. However there were shorter TT's and some that had extention tips that connected via a shaft adapter similat to the 944 TT to transaxle sleeves...
anyways here's what I found on a couple of the TT's (I think these were 5 speed TT's) I may stand corrected....
Re: 928 TT dimensions
Post  gt1scca on Fri Sep 25, 2009 2:46 am
Flange?
Bolt pattern?
The 928 uses a coupler @ the flywheel - can be eliminated when installing GM V8.
I came up with a 944 to 928 TT dimensional difference of 3.76".
Hmmm, sounds about right...(using the SMS method) Razz
Post  Tetzuoe on Fri Sep 25, 2009 7:55 am
gt1scca wrote:using the SMS method
I am certified, Looks good to me
Tetzuoe
Post  xschop on Fri Sep 25, 2009 9:18 am
Flange?
Bolt pattern?
After seeing all the 944 Flange dims off everywhere I didn't bother.....Figured I would use the SMS system when I make an adapter Razz
It was dark inside the building and mosquitos galore, had to bail quickly affraid
I did see that there was a short and long tube as well, maybe one was for Auto and the other for Manual, but not 100% sure either.
Post  realcarfreak on Sun Sep 27, 2009 8:48 pm
Hello,
This is my first time posting... I think there are at least two different lengths of torque tubes in the 928 manual cars. Perhaps the slip collar offers some minor tolerance for BH adapter length?
If we could just get the TT face dimensions... Not sure what SMS is. Must be something similar to my portable Lufkin dimensioning system ($6 at the HomeDepot) drunken
Here is a picture I found in a TT rebuild post that adds some pieces to the puzzle
realcarfreak
Post  realcarfreak on Sun Sep 27, 2009 8:53 pm
Here is another bit of information related to the original 928 manual configurations.. Single and Dual disk
realcarfreak
Post  gt1scca on Sun Sep 27, 2009 9:29 pm
Yep...
Saw those. Flange bolt pattern is what we still need.
S.M.S.:
Post  xschop on Mon Sep 19, 2011 9:18 pm
Ok back on this subject. The first pic with the longer 1 piece shaft is the AUTOMATIC Torque Tube and the 5-speed has a coupler designed so clutch changes are easier....I wish the 944 had a 2-piece with coupler but that's another story.... Anyways that coupler has a maximun rotating dia. of 2.75" (Eric) and another measurement of 2.73" by Constantine. Measure twice cut once right? By the way, if you haven't heard, Constantine, the TT rebuild guru is building all-new 944 Torque Tube Shafts from stronger steel and even Zinc Plating them. So if you have a Renegade kit, you might want to contact him Razz
Anyways, I don't build anything on SMS so I will get the 928 Flange dims from him and if Eric can confirm, we're on our way.
TT
Post  fliermike45 on Mon Sep 19, 2011 9:25 pm
Constantine rebuilt a 944 shaft for me, his work is first class.
