Engine stall under load
Just finishing up a swap with a 5.3 using the Ford Mustang hydro boost and I'm having a problem. When I press the brake or turn the steering wheel with it idling it immediately kill the engine. I’ve been searching forums and wracking my brain over this, has anyone experienced anything similar? I'm probably overlooking something and I'm sure it's somthing simple but for the life of me I haven't been able to figure it out.
Torc_TX- Posts : 3
Re: Engine stall under load
Is the idle control valve working properly? Do you have a scanner to check for codes / read iac count?
What throttle body do you have?
zeusrotty- Posts : 444
Scanner doesn't read any codes. I'm not sure about IAC count. It's also bogging down on WOT.
Torc_TX- Posts : 3
Hydraulic line crossed?
racertomtom- Posts : 144
racertomtom wrote:Hydraulic line crossed?
Yes, it sounds like there's too much back pressure on the PS pump, which is causing the stall.
Thanks, let me try that this afternoon when I get off.
Torc_TX- Posts : 3
» Engine fails when getting warm under load or idling
» WHAT ENGINE IS THIS?
