What are these - Trying to get fire
Ok so I uncovered my project after a year or so. I am trying to get the wiring correct. I purchased a complete wiring set up with fuse block from SSP Wiring in Arizon that came with the engine I bought from them. I am now trying to tie everything in. I was told that all that needed to be done with run a wire to the ignition and starter. I am not sure that all that left. Trying to make heads or tails of what needs to be done to get it to turn over. what are the pics below -- if anyone can help
What about this
What about this
Red944ls1- Posts : 98
Re: What are these - Trying to get fire
Moved this electrical
The two pin connector is for the starter and alternator; the red comes from the ignition switch and goes to the starter selonid. The blue is the alternator excite wire.........cant recall what the larger plug is for. What year and model is your car?
The first picture is the cruise control unit connector.
Techno Duck- Posts : 447
Its a 1984 NA -- I dont think my car had cruise on it.
So with the Wire from the ignition -- I would run that to the starter (the red one) and the other I would run to the alternator The alternator does have a connected already wired from the harness.
