» Dual MC Mounting Bracket
Today at 8:11 pm by 87944turbo
Today at 7:50 pm by hp18racer
Today at 5:20 pm by dougr944
» Need help! Car won’t start
Today at 3:51 pm by jess2suityou
Today at 9:44 am by keetle
» Brand new ls3 build
Today at 9:32 am by Plucky948
» Lighten clutch pedal feel?
Today at 1:35 am by Porsche951toLS3
Yesterday at 9:54 am by docwyte
January 2019
78910111213
14151617181920
21222324252627
28293031
Engine stall under load
Post  Torc_TX on Wed Oct 22, 2014 8:47 am
Just finishing up a swap with a 5.3 using the Ford Mustang hydro boost and I'm having a problem. When I press the brake or turn the steering wheel with it idling it immediately kill the engine. I’ve been searching forums and wracking my brain over this, has anyone experienced anything similar? I'm probably overlooking something and I'm sure it's somthing simple but for the life of me I haven't been able to figure it out.
Torc_TX
Re: Engine stall under load
Post  spence on Wed Oct 22, 2014 9:22 am
Is the idle control valve working properly? Do you have a scanner to check for codes / read iac count?
Post  zeusrotty on Wed Oct 22, 2014 3:30 pm
What throttle body do you have?
zeusrotty
Post  Torc_TX on Wed Oct 22, 2014 5:51 pm
Scanner doesn't read any codes.  I'm not sure about IAC count.  It's also bogging down on WOT.
Torc_TX
Post  racertomtom on Wed Oct 22, 2014 6:46 pm
Hydraulic line crossed?
racertomtom
Post  Lemming on Thu Oct 23, 2014 7:44 am
racertomtom wrote:Hydraulic line crossed?
Yes, it sounds like there's too much back pressure on the PS pump, which is causing the stall.
Post  Torc_TX on Thu Oct 23, 2014 8:07 am
Thanks, let me try that this afternoon when I get off.
Torc_TX
