» Transaxle rebuild
Today at 8:51 pm by yamamtx
Today at 8:27 pm by matt889
» Hello, Gentlemen.
Today at 7:43 pm by rawr
Today at 7:37 pm by Porsche951toLS3
Today at 7:17 pm by Porsche951toLS3
» alignment specs
Today at 12:53 am by sharkey
mls head gaskets??
mls head gaskets??
Post  smither944 on Mon Oct 06, 2014 3:30 pm
hi i think Im in the right place to post? If not please let me know. I just had a valve spring break.....Didn't hurt piston but bent the valve,so had to remove the head. I used Mr. Gasket MLS Head Gaskets 3133g. can i reuse it????? the gasket i mean? thanks any input welcome..
smither944
Re: mls head gaskets??
Post  smither944 on Mon Oct 06, 2014 7:44 pm
sorry the car is a 89 944 with a sbc 5.7 twin turbo ..stock lower end, 5 to 8 psi
smither944
Post  944-LT1 on Mon Oct 06, 2014 11:13 pm
Yes, totally reusable. They are all metal so don't fall apart like conventional gaskets. Don't clean them with harsh chemicals (soapy water is fine) due to the "proprietary coating" and use some copper coating after they're clean.
Make sure those head bolts aren't stretched though.
Post  smither944 on Tue Oct 07, 2014 6:34 pm
Hi, thanks for the input...copper coating? How do I tell if the head bolts are stretched? The head bolts are new and have only been torqued once. Thank you.
smither944
Post  944-LT1 on Tue Oct 07, 2014 8:29 pm
Copper gasket sealer is an aerosol spray sealant sold at your local auto parts house. Highly recommended for high HP applications and for MLS gaskets.
I don't think you have an LS series engine so never mind the bolt thing. Have fun! Very Happy
