trans options???
trans options???
hi newish to the forum, Im running in to a small issue , my car is a 86 944 , Currently has a sbc with twin turbos, pushing about 460 to 490hp on 8 psi. also just tore the ring and pinnon out of the transaxle,and it was a lsd. Is there any other trans options?? Other than a turbo lsd trans. sorry about the spelling, bad typer. Also a very good fabricator.Trying to post a pic.
smither944- Posts : 14
Re: trans options???
What is the car being used for, daily driver, drag racer, etc?
Turbo LSD is what most are using, but if you are a good fabricator, you can install the TT and transaxle from a Z06, or throw in a quaife transmission.
Mostly daily /week end driver .hope to install a 5.3 on boost,goal is around 600/650 hp. s10 rear end and a th350 trans? thanks for the interest..
Search around for Admin's first car. It had an engine mounted trans and a Ford 9" rear, IIRC.
https://i.servimg.com/u/f39/19/00/21/76/deanph13.jpg
This is my toy if you can see it.
You’ve certainly got the cool factor going. Show and bragging rights make up the rest of a “street machine”. I’ve been a long time proponent and participant of “car crafting”. The original run what you brung hobby where a builder expresses his ideas with skill as to what a street machine is. With that said, you tell us what trans it should have. A nine inch locker and 4/5 speed manual would be better if you hit 650 HP but you won’t likely hook it up on the street anyway. Drag racing? Then powerglide with a nine inch spool. If you want it to still handle like a sports car then stay with a transaxle but never ever swap feet very hard.
racertomtom- Posts : 144
Yeh there is a lot of time in the old girl ,but worth it .(iF U CANT BUY IT,BUILD IT).any prodution 5 speed that will handle it.World class t5 ? out of a camaro .?Will do a custom 4-5 link to hold the rear.no drag racing. i do have a saginaw 4 speed twin stik??.I dont expect it to hook if around 600+ hp just be fun to drive.Love the pull when boost comes in
There isn't a T5 in the world that will take that kind of power.
Pretty much all you can do is swap in a Corvette transaxle (very difficult) or a regular transmission behind the engine (very bad option because the tunnel is structural in these cars and normal transmissions don't fit in it).
So pretty much you're just stuck with a Turbo transaxle, but even then, those won't hold up to much more than ~425 horsepower. That is why nobody builds really high HP 944's...
I didnt think they made a serious t5 ether.. a buddy says it would. Is there a lot of tunnel mods required?? What about a tremmic 5 or 6 speed of sorts?? Thanks for all the interest .
They've made some pretty decent T5's but they top out in the 300-something horsepower range. They are a small and relatively light transmission, you just can't beef them up enough. The T56 (Corvette, Viper, etc. 6-speed) can be made plenty strong but again, nothing fits in the Porsche's tunnel because it wasn't made to fit a transmission.
The transmission thing has been discussed a lot on here, you should search around and see what people have done. For the most part people just give up and install a Turbo transmission and hope for the best, though...
Thanks.Ill do some digging ,maybe some one has done this....
