» V8 Conversion Parts
Today at 3:46 pm by lawn_mower
Today at 1:22 am by 964ruf
» PCV routing??
Thu Aug 09, 2018 9:52 am by Rich L.
Thu Aug 09, 2018 9:31 am by chrenan
» 944 conversiobs
Wed Aug 08, 2018 8:40 am by Hotrodz of Dallas
» Drag set up
Mon Aug 06, 2018 11:19 am by Hotrodz of Dallas
Sun Aug 05, 2018 6:40 pm by LSA_944
Sat Aug 04, 2018 11:17 am by acorad
» Mustang hydroboost valve cover clearance
Sat Aug 04, 2018 9:48 am by matt889
» Who uses Mustang MC with Hydroboost in 944 ?
Tue Jul 31, 2018 9:33 am by chrenan
August 2018
6789101112
13141516171819
20212223242526
2728293031
Intake woes
Intake woes
Post  quarterflash on Tue Sep 16, 2014 9:04 am
Trying to find a an elbow that wll fit the throttle body and mate up to the MAF etc appears to be an impossible task but the rest of you must have managed it somehow. See pics below for space.
I have looked through the LT1 forum and intakehoses.com replied to my email saying "I'm not aware of any current hose that will fit there."
Any suggestions?
I would prefer to keep the exisitng latch mechanism. Thanx,
Q
quarterflash
http://porschevy.co.uk/
Re: Intake woes
Post  948 on Tue Sep 16, 2014 12:09 pm
I am using something very similar to this, bought it 10 years ago now so I am going by memory..... [You must be registered and logged in to see this link.]
IIRC the elbow had a 4" and 3" diameter....check to be sure.
I then shortened the length of the t-body section down. The elbow does touch the latch and hood, very very slightly. BTW, you may have to remove some of the ribs on the hood to clear the t-body/elbow.
Paul
Re: Intake woes
Post  quarterflash on Tue Sep 16, 2014 1:10 pm
Hi Paul, Thanks for the info. What is IIRC?
Does the elbow have an oval opening or does it stretch and squash from a round when you put the clip on?
So you removed some of the metal from the front of the throttle body so that the elbow would sit further back?
We will be cutting the fiberglass hood and inserting a bulge to clear everything.
Thankx
Q
quarterflash
Re: Intake woes
Post  948 on Tue Sep 16, 2014 3:53 pm
quarterflash wrote:What is IIRC?
If I Recall Correctly.
quarterflash wrote:Does the elbow have an oval opening or does it stretch and squash from a round when you put the clip on?
It is very flexible, so it can be either round or oval.
quarterflash wrote:So you removed some of the metal from the front of the throttle body so that the elbow would sit further back?
No, i only removed material from the t-body leg of the elbow....see image below, the red line is approximately where I cut.
Re: Intake woes
Post  quarterflash on Tue Sep 16, 2014 4:34 pm
That's great - many thanks.
Q
quarterflash
Re: Intake woes
