Mon Jul 08, 2013 5:56 pm by Admin
Today at 3:35 pm by kevin924kevin
» New 944 widebody & aero
Yesterday at 7:56 pm by scryfst
Yesterday at 1:23 pm by Murrdog9000
Wed Feb 21, 2018 8:41 pm by 962porsche
Wed Feb 21, 2018 12:58 am by 948
Tue Feb 20, 2018 6:25 pm by acorad
Tue Feb 20, 2018 2:51 pm by acorad
» Oil Pan question
Tue Feb 20, 2018 11:41 am by Rothaus
» 83' Porsche 944 LM7 Build
Mon Feb 19, 2018 3:39 pm by Jchard944
» Throttle body question
Mon Feb 19, 2018 2:02 pm by Rothaus
1990 944 S2 with LS1 and lots of goodies
Post  Porch on Mon Aug 25, 2014 11:54 pm
Up for sale is a 1990 Porsche 944 S2 with an LS1 swap pulled from a 2001 Firebird.  The car has too much stuff done to it to get a comprehensive list going here, but i'm happy to go into detail for prospective buyers.
Black 1990 944 S2 - 200k on the odometer but you wouldn't know it from the car itself.  The car does have dents and dings but the paint is solid and the car has probably been garaged its whole life.  The car came from TX (now in NM) with no rust anywhere.  The car has been to the road course a few times and one or two autocrosses but mostly has been a weekend cruiser.  Selling to pay off student loans!  The car is ready to start up and drive away.  I would not hesitate to drive it across the country right now.
  • 2001 LS1 (purchased with 38k, has had 30k put on it since then)
  • LS6 PCV system
  • Mild cam - 224/224, .575/.575 Isky cam with Isky tool steel beehive springs and Ti retainers.
  • RH swap parts -- ceramic coated headers, kevlar HD clutch, poly motor mounts, oil pan, etc.
  • A0R transaxle -- the holy grail of 944 transaxles!  LSD and external cooling, shot-peened gears, etc.  Added N/A 5th gear for lower freeway RPM.
  • Mustang Hydroboost with stock Brembo 4-piston Turbo calipers and drilled/slotted rotors.
  • Koni yellows all around in good shape.
  • 300# front springs with GC coilover conversion, Ground Control CC plates
  • 28mm torsion bars in the rear (300# equivalent) w/ Elephant Racing Poly Bronze bushings
  • 968 M030 sway bars F&R
  • Rebuilt front control arms
  • Rebuild power rack and pinion (older rebuild, but no leaks)
  • Custom interior: Top half is black, bottom half is maroon.  Leather.  Dash not cracked!!  (This is not a color combination that was offered)
  • Constantine's torque tube bearings
  • Morimoto Mini HID projectors
  • New OEM windshield with "clear blue" tint (blocks 99% UV and cuts heat by 20%, but completely invisible)
  • Texas Performance Concepts tie rod ends
  • Short shifter on transmission (forgot the brand) and modified shifter at the front with custom bushings and knob.
  • 993 TT Hollow Spoke rims powdercoated white, 18x11 and 18x8.5 - 225 front and 285 rear
  • Turn One power steering pump made for hydroboost and the Porsche rack
  • Texas Performance Concepts lower lip
  • Full 3.5" exhaust
  • 2x High flow cats
  • New alternator
  • Lots, lots more...
+ spare radiator, axles, turbo fuel pump, external oil cooler, a/c compressor for the LS, and more.
I performed the swap myself, but don't let that scare you.  I have received compliments on the swap from numerous shops, including one that came with a job offer.  I worked at a hot rod shop most of my way through college and have built a number of cars prior to this one.
The car was a daily driver for a few years (except in bad weather) but these days i usually only drive it once or twice a week, for the whole 3 miles to my work.  The car has been dead reliable.
I would recommend that the buyer plan to have the car tuned, as it is set up for very high elevation right now (7200ft).
Some more pictures here: [You must be registered and logged in to see this link.]
Asking $21,500.  I am not in a rush to sell.  Contact me at ccollord-at-hotmail-dot-com if you'd like to discuss!
Re: 1990 944 S2 with LS1 and lots of goodies
Post  Rich L. on Tue Aug 26, 2014 2:36 pm
Good lookin' car! GLWS
Post  Porch on Tue Aug 26, 2014 4:12 pm
Thanks!
A little sad to be finally putting it up for sale, but for the last two years i've lived in a town with 35mph speed limits and 3 mile drives to work...it just doesn't get the use that it should.
Post  mr965 on Fri Sep 26, 2014 11:44 pm
Nice. Good luck.
mr965
Post  Porch on Mon Aug 17, 2015 7:10 pm
Bump! Back up for sale, asking $21.5k
Post  Porch on Thu Sep 03, 2015 10:58 pm
Sold!
Post  docwyte on Fri Sep 04, 2015 12:17 pm
Congrats, sad to see you go!
Did you get what you wanted out of it and did it sell from the ad here?
Post  Porch on Fri Sep 04, 2015 3:34 pm
Thanks docwyte, sad to be leaving! We just had a kid and I'm just too busy with other stuff to enjoy the car anymore. It's been fun though!
I got $16k for it. Not what I was hoping for, but it needs a few little things (tires, alignment) and I just don't have the time or money to keep it up the way it deserves.
