» alignment specs
Today at 12:53 am by sharkey
Yesterday at 9:46 am by JSP
» Transaxle rebuild
» Tpc LS adapter plate
The beast rumbles into action
Post  quarterflash on Fri Aug 22, 2014 12:00 pm
We have at last managed to get the lt1 to fire up. You can see the video here - .
Note UK right hand drive.
We now have a problemn with the clutch pedal being soft. It bleeds ok but has no hardness. It is the stock 944 turbo MC and the RH bellhousing and slave.
Build photos here - project build photos
Thanx
Q
quarterflash
http://porschevy.co.uk/
Re: The beast rumbles into action
Post  Lemming on Fri Aug 22, 2014 1:21 pm
Great to hear it running.
How did you bleed the system? I have great luck with the motive power bleeder, just reassembled my clutch last night, (new slave and master) and with one bleed it was working great!
Post  admiralkhole on Sun Sep 14, 2014 7:15 pm
The slave cylinder sits at a slight angle and needs to be removed from the bellhousing for bleeding. Worked for me an a couple others I've talked to. Good luck!
admiralkhole
Post  quarterflash on Mon Sep 15, 2014 3:20 am
Hi,
Thanks for the info. We now have the clutch operational. It seems to have been pipe sizes and fluid displacement that was the issue as well as the slave push rod length.
Maybe a master cylinder size upgrade would be advisable for the future.
Q
quarterflash
