BOOSTER DELETE
+12
Tetzuoe
turbobob924
m73m95
coctostan
golfduke
Johnny Johnny
16 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Bye Bye cereal bowl
I put this Tilton Dual MC housing against the firewall....
The cereal bowl is history. I will have to re-figure the pushrod length.
Question, Why did the original cereal bowl put the booster, MC at an upwards angle?....Prevent Air in lines?
I can figure the angle it created and get rid of the bowl and angle right off the firewall. But if I come right off the firewall, the Dual MC setup will stick straight out and still clear the valve cover by an Inch.
Same features, Wilwood looks "cool"...
WILWOOD...
gt1scca- Posts : 795
Merger...
I may merge this thread with the Tilton Dual MC thread...
Last edited by gt1scca on Wed Jun 24, 2009 2:25 am; edited 2 times in total (Reason for editing : No patent...)
merger
Wilwood or Tilton Compact MC's are the ticket.....
Get your merger on....
I do recognize that the tilton has a 3/8-24 outlet port though....
Hey Dawgz, I also recognize that your strut tower brace is not set-up right......That Heim joint renders it useless.....
Must be copyrighted...
EDIT: Didn't work...
Re: BOOSTER DELETE
xschop wrote:Wilwood or Tilton Compact MC's are the ticket.....
Is that because it moves? I bought it like that and had to space it out a little to clear the hydroboost. Once it's bolted in i tighten the bar then lock down the locking nuts. What can I use to fix the problem with it?
Dawgz83948- Posts : 603
Re: BOOSTER DELETE
Yes, the heim joint moves and pivots, even moreso since it is spaced far out from the tower clamp.
I will be designing one later and the heim should be affixed between to points on the strut clamp so the forces are properly transferred from tower to tower.
Strut Brace
http://www.lindseyracing.com/LR/Porsche/944STRUTBRACE/RD-944-99-00.html
(Kinda pricey, but the mounting is better...)
Re: BOOSTER DELETE
The angle is related to the path that the pushrod takes from pedal to booster/MC. The rod should remain as close to parallel with MC bore axis as possible. This will prevent binding and excessive moment loads on the rod and MCxschop wrote:I put this Tilton Dual MC housing against the firewall....
If you were to move items around you could determine the angle needed by the following:
Draw a straight line through 3 points with the pedal fully up.... MC axis, booster axis and pedal pivot centre; the resulting line would be your hypotenuse and the firewall would be your vertical line. Also perform this with the pedal fully depressed, under pressure. Take the difference of the two and that should be close to what you will need.
Angle of attack
Thanks Paul. I see why the simple single delete plate is machined upwards by 14mm.
However, this Dual MC housing has a 1:1 pivot cam on it and connects to a pushrod via a Heim joint. Since it is best to install it sideways (for valve cover clearance) with the cam directly centered in the firewall hole. I don't see any binding taking place.....
You could actually move it over another 1-1.5 inches if you were to install a Heim-joint on the pedal side.....
I will start designing the adapter plate needed to mount it to the firewall.
Re: BOOSTER DELETE
gt1scca wrote:http://www.lindseyracing.com/LR/Porsche/944STRUTBRACE/RD-944-99-00.html
Won't work with the hydro boost setup.
heim
Get rid of the heim joints and install solid rod ends, Even then the offset of that stud will still flex and not transfer forces correctly unless the cross-rod is moved back up against the tower.
Re: BOOSTER DELETE
That is one of the main reasons I was looking at that style of mount.....I am glad that you are going to make it happen. It will make Michael happyxschop wrote:this Dual MC housing has a 1:1 pivot cam on it and connects to a pushrod via a Heim joint. Since it is best to install it sideways (for valve cover clearance) with the cam directly centered in the firewall hole. I don't see any binding taking place.....
BTW, did the excel sheet I sent make sense/help?
spread um
Yeah, the excel sheet is now part of my 8 gig usb drive
Hey Paul, I was discussing with Greg that the Wilwood shorty MC's had outlet ports of 1/8"?????
and the Tilton shorties had 3/8-24.....That's confusing, I hope Wilwood tech sheet wasn't a misprint.
What do you think about 2ea of the 1" tilton 75-1000U MC's with all 4 corners of the car having the 4x42mm Lexus calipers? 60-40?
Re: BOOSTER DELETE
xschop wrote:Yeah, the excel sheet is now part of my 8 gig usb drive
Most of the Wilwood MC's I have seen (I have 2 at work on the bench for an R+D project ) have the 3/8-24 UNF thread for the output....did you check the website?
Also check out AP's products, they are one of the best in the world. AP Racing <==click me!
Email me the details of the calipers, MC's and pedal ratio. I can throw it in the sheet.
Also, are we sure that 1 inch stroke is enough??
Re: BOOSTER DELETE
I'm not 100%...948 wrote:...Also, are we sure that 1 inch stroke is enough??
Re: BOOSTER DELETE
What is the stock 944 pedal ratio?
I would like to go with the shorties, but the normal lenth MC's will fit also with no problem mounted on this housing, they have a longer throw/stroke....8x42mm pots for a 1" MC, the big question is the stroke length then....
Re: BOOSTER DELETE
Tilton determine the appropriate MC sizing for you. You just have to contact them with braking system details.
You really want to get this right from the start. Rear lockup is dangerous. Also, don't rely on balance bar for major adjustments. Get it close from the start and use the balance bar for tweaking and for varying track conditions.
Another option on the pedal is a simple custom setup. This way you can be certain it is stiff enough and it can be drilled for differing amounts of leverage.
Example from a Mustang (http://www.maximummotorsports.com/index.html?http&&&www.maximummotorsports.com/store/index.php?main_page=product_info&cPath=21_88_194&products_id=485):
coctostan- Posts : 25
Re: BOOSTER DELETE
[quote="xschop"]What is the stock 944 pedal ratio?[quote]
My estimate is in the excel sheet I sent.......I don't have it on this computer.
pedal ratio
Forgot to reply with the 5:1 ratio that is stock 944.
I am working out the details on putting all 4 corners of the brakes with the Lexus 4x42mm calipers.
Mike the Tilton Rep/engineer recommends using a 5/8" MC up front and 1" MC for the rear to decrease the rear pressure. Greg and I are working out the best solution or upgrade for the rear rotors for the NA cars....
firewall plate
Got some 1/4" billet plate for the firewall piece. I think I will screw countersunk bolts thru the backside of this plate to the perpendicular plate that the Balance bar will bolt to. I may also just welsd up some 1/8" steel plate and brace it....
Re: BOOSTER DELETE
xschop wrote:Forgot to reply with the 5:1 ratio that is stock 944...
5:1 is assisted...7.6:1 for manual, which is what this setup will be. Recalculate xs...it takes more lever to do the same work with no assist. It's also why the FW area needs to be reinforced.948 wrote:My estimate is in the excel sheet I sent...
(ya spent too much time on that avatar...)
EDIT: Make me a plate while you're at it...
pedal ratio
I thought the stock pedal was drilled 5:1 ????
Re: BOOSTER DELETE
It is...ask Paul to be sure, but he calculated the manual ratio to give ~ 2.5" of pedal travel.
Page 3 of 4
