» ABS issues
Yesterday at 6:50 pm by kevin924kevin
» Cadillac LS6?
Yesterday at 1:50 pm by cjbcpa
» Another 928 rescue & swap thread .. considering an L33
Yesterday at 3:40 am by attes
» Hot relays and high voltage.
Sat Oct 18, 2014 10:36 pm by racertomtom
» 83' Porsche 944 LM7 Build
Sat Oct 18, 2014 12:04 pm by erioshi
» Oil cooler routing
Fri Oct 17, 2014 10:26 pm by racertomtom
» Lots of brand new swap parts. Parting out my whole car.
Fri Oct 17, 2014 5:05 pm by Jchard944
» WTB.... 2 piece C5 bellhousing
Thu Oct 16, 2014 8:51 pm by xschop
» 5R code 1987 951 LSD/Oil Cooler Transaxle
Thu Oct 16, 2014 4:05 pm by Audisigh
» LT throttle cable
Thu Oct 16, 2014 1:06 pm by 948
October 2014
6789101112
13141516171819
20212223242526
2728293031
Turbo 5.3 T56 944 Build
Post new topic   Reply to topic
Post  Sentronix on Mon Aug 04, 2014 1:11 am
I will be using this thread to document my 5.3 LSx into my 1985.5 Porsche 944.
Plans for the car:
Aluminum 5.3
T56 6 Speed Transaxle from a Corvette
Custom built turbo kit
BW S366 Twin Scroll Turbo (my goal is to have the BEST powerband for street use)
The car when I picked it up.  It had a blown head gasket (at least)
Tearing down the motor to take it out:
Motor out:
I picked up a Junkyard Aluminum 5.3.  Hoping to make 600+whp with this!
started stripping it down right away and degreasing:
Got all of the mating surfaces clean
Special tool for removing crank pulley bolt:
TPC Mounts:
T56 Swap parts:
Beginning of turbo parts
Tial 44mm wastegate (need another) and a Tial Q blow off valve.
Sentronix
Re: Turbo 5.3 T56 944 Build
Post  Sentronix on Wed Aug 20, 2014 10:09 pm
Maybe this photo will earn me some responses
Sentronix
Post  xschop on Thu Aug 21, 2014 6:04 am
Just a good old fashion hell yeah.
I see why those pics of the 930 adapters have a long taper run on them now. The ODs of the bigger joints probably don't clear the alloy arm inner recesses. Good find.
Post  Sentronix on Thu Aug 21, 2014 1:38 pm
Yes, they look like a great design. You interested in machining a set?
Sentronix
Post  xschop on Thu Aug 21, 2014 5:07 pm
There must be a Co. Making them. Do you have a .jpeg copy?
I called Patrick motorsports and confirmed that their adapters were 78mm PCD (type 1).... No go.
Post  Lemming on Thu Aug 21, 2014 6:12 pm
Looking forward to watching the build!
