First Drive LS3
+4
bluejk09
thom
8 posters
First Drive LS3
Hello guys, Milkman and myself finally took the LS3 conversion for it's first ride. WOW super cool!!! Looking forward to finishing it up and track it. I posted a gopro video on youtube.
thom- Posts : 31
Re: First Drive LS3
Awesome! I look forward to more pics and videos.
bluejk09- Posts : 18
Re: First Drive LS3
Here's another with a drive by view.
thom- Posts : 31
Re: First Drive LS3
New 2 stroke LS3.Admin wrote:Pretty cool, how'd you make it sound like a leaf blower?
thom- Posts : 31
Re: First Drive LS3
[img][You must be registered and logged in to see this image.][/img]
thom- Posts : 31
Re: First Drive LS3
This is the kit that was installed. We deleted the P/S pump and A/C and measured for the correct length serpentine belt. We will be replacing the self adjuster with a manual one.
thom- Posts : 31
Re: First Drive LS3
Yeah, good. I had the belt jump off the spring tensioned self-adjuster this spring. Everything seems good now with the clamp tensioner instead.
That air cleaner looks great as long as you keep air pressure in front of the rad.
Re: First Drive LS3
Thanks Rich, We still have a lot of work to do as in fabricating a wall to separate the air filter and radiator. It's just nice to see a light at the end of a tunnel.
thom- Posts : 31
Re: First Drive LS3
It's been on the road for some time now and finally had it on the dyno for a tune. We were able to put down 468hp to the wheels. Car has been trouble free since the build. Looking forward to a track day this year to test it out properly. Hopefully we can get Techno Duck there on the same day.
thom- Posts : 31
Re: First Drive LS3
October 4th and 5th at NJMP!
Techno Duck- Posts : 447
Re: First Drive LS3
Nice, now get it out there and flog it on the track!
Re: First Drive LS3
Nice work Thom!
I'm going to run a similar floor mounted Tilton setup.
Mind divulging the cylinder sizes you are using for the brakes and clutch?
Thanks mate,
Lee.
Thanks mate,
Lee.
XtaC- Posts : 9
Re: First Drive LS3
Thom....468 HP to the wheels is outstanding!! I think you're going to have a lot of GREAT track days.
Reopening your thread called my attention to your engine bay and like XtaC I'm very interested in your brake and clutch set-up. I used Holley valve covers with LS2 coil packs in My LS1 build and I would like to keep my PS and keep my coil packs on the covers.
I also love your air intake approach as well!
Nice job!!
Ray
Nice job!!
Ray
Raymond-P- Posts : 373
Re: First Drive LS3
Ray and Lee, I ended up using Tilton 75 series pedals with .625 " front master, .700" rear master and .875 for the clutch. We are also using a Quicktime bellhousing so the shim calculation was a little more complex due to the mounting surface of the slave in the bellhousing. We also use a remote brake bias set up. This helped balance it out a great deal more. The front calipers were changed over to Big Reds and the rears are stock turbo blacks. If you search for "floor mounted Brake Pedal" you will find additional information and photos from other users also. Good luck with you cars. Thom
thom- Posts : 31
Re: First Drive LS3
Also Ray, to do the intake without it hitting the hood, I lowered the radiator mount enough to clear the aluminum tube. Basically cut and rewelded the lower mounting rail and extended the upper retaining bolts with bushings.
Thom
Thom
thom- Posts : 31
» Early 85 944 Supper Quick Build
» Cranks, but nothing else (Surprised? no)
» LS1 into RHD (Right Hand Drive) 944
