L33 Ls Conversion
L33 Ls Conversion
Hey There Guys
I have rethought my project here and am going to sell my 410 SBC I had built for my 944. I don't want to put a big hood scoop on the car and want to get better mileage. So, I am looking at a L33 LS motor with a turbo cam swap with intentions a putting a small single on it down the road.
My question is centered around what goes between the motor and the torque tube. I can get all of the bellhousong/flywheel/clutch/pressure plate/hrd throut brg...everything just as it came out of the donot vehicle.
At this point what do I need to mate this to the torque tube? Would I need that C5 belhousing adapter on the texas website? Then what do I do in the back of the crank for the pilot bearing? Do I buy the bearing kit off their website?
I have spent some time on the forum here and am really enjoying the research but cannot seem to find out about these 2 items!
Thanks for your help,
Ed
Ed
mred2nice- Posts : 79
Re: L33 Ls Conversion
When I bought my tt adapter from TPC it included a thowout bearing adapter and bearing. Then all you need is a C5 2 piece bell housing and a dodge clutch disc to work with a gm flywheel and pp.
wingdog- Posts : 15
well I'm not sure what the common answer is but my recommendation is to bust out the calipers and figure out what size you need and order it from mcmaster-carr I suspect this is the cheapest way to go
drive135mph- Posts : 9
I used the one supplied when I bought my swap kit, works great, fit great, no problems what so ever, and I beat the crap out of my car.
Andy
Andy
99sierra4x4- Posts : 121
Today at 9:56 am by ndog52
