VSS install- do I leave the washers that bridge two bolts?
Hi- OK Been a long day and hopefully this is not a super dumb question, but when installing admins VSS do I leave the washer/spacer things that bridge two bolts at a time or delete?
Also, while disassembled should I pack in more lube? If so, what kind. Many thanks-
Jasonscottw- Posts : 125
Re: VSS install- do I leave the washers that bridge two bolts?
I did not use the washers.
I would only put lube in if you have lost some. A moly based grease is best.
Thanks 948. I'll skip the washers-
» Help, I cannot find a 10.9 or 12.9 m14 x 1.5 x 85mm bolt for the life of me.
» Stage 8 Locking CV Bolts
Today at 12:47 am by sharkey
