Engine Harness with LS swap
What did you guys do for an engine harness?
Hammerhd- Posts : 23
Re: Engine Harness with LS swap
Im using a new PSI standalone harness. Quality and zero issues. It even has the reverse lock-out connection for the 6 speed .
Are you using your stock porsche gauges?
I used a harness from Painless Wiring. Easy hook-up and a great manual came with it. But stock wiring remains for factory gauge hookup. Search on here for the "14-pin connector".
» FS: LSx swap parts; remote oil filter mount with fittings, engine harness boot
» F Body Engine Harness
» Disconnecting the engine wiring harness
