» What is VSS?
Today at 10:53 am by C4924S
» The famous Hydroboost issues....
Today at 10:43 am by Hotrodz of Dallas
» RHD Conversion Issues...
Yesterday at 4:24 pm by UK952
» Considering doing LS1 Swap
Sat Apr 21, 2018 10:29 pm by hooplajr5
» WTB: 944 Turbo Roller
Sat Apr 21, 2018 8:31 am by Maxx
» Blue Alternator Wire
Fri Apr 20, 2018 11:22 pm by Porsche951toLS3
Thu Apr 19, 2018 4:01 pm by Murrdog9000
» Team Moroney's LS1 944 Swap, In memory of Kyle Moroney.
Thu Apr 19, 2018 6:16 am by bikerdude
Thu Apr 19, 2018 2:33 am by Flashy2003
» ecotec swap
Thu Apr 19, 2018 12:13 am by sharkey
April 2018
30
Turn one pump without a reservoir?
Post  murrayg on Thu Jun 26, 2014 7:43 am
I've removed the reservoir from my Turn One PS pump and will run the larger BMW tank. This is required when using the BMW HB system. Once the reservoir is removed, how do you attach an inlet hose to the pump? Is there a clamp on plate with a hose fitting available?
Gord.
murrayg
Re: Turn one pump without a reservoir?
Post  87-944S on Wed Aug 27, 2014 5:40 pm
Hi Gord,
I did the same, I made a bottom tap from some cheap Harbor Freight NTP taps and tapped the inlet. I then used a NPT to AN adapter to provide connection to the reservoir.
Here's a thread with some pics of what I did.
http://944hybrids.forumotion.com/t1924-bmw-hydroboost-reservoir
Good luck!
Mike
