Frosty's 83 944 LM7 Project
+5
frostyballs
wingdog
majormojo
99sierra4x4
9 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Engine and Suspension Work
I figure I'm over due for an update. My second attempt at rebuilding the 5.3 has gone better than the first. I'm waiting on a couple new sensors from Summit, then I'll be fitting it in the car. I've spent the last couple days swapping over the front hub, rotor, and calipers from the 86 turbo donor car to my 83 build. The right side is all together, and the left will be finished today. I've decided to keep the early steel lower control arms, due to the lower cup bushing being replaceable, unlike the later aluminum arm.
Here's the right front, with the little black 4 piston calipers.
Putting the bottom end together.
Putting the cam in.
Left side lower control arm dis-assembly.
That's all for now. Thanks for checking out the progress.
Putting the cam in.
frostyballs- Posts : 25
Sale of Project
Due to medical difficulties I'm considering selling the project. It will include both cars and the TPC conversion kit. I will be keeping the v8 and taking care of it separately. Please let me know if you have any interest and I will gladly provide any details. Thanks.
Mike
253-232-6155
Mike
253-232-6155
TPC mounts and spacers
I am continuing to work on the car, despite listing it. I'm on the fence, but feel like I might be able to keep going with it. I've been working on the motor mounts and cross member spacers, courtesy of TPC. While removing the cross member for the first time, one of the larger M12 bolts broke off deep in the hole, it was rusted in pretty good. I've drilled out the hole with a left handed bit, but nothing came loose. My plan is the drill it back to stock size and then attempting to tap the hole.
I'm also finishing up pulling the turbo trans from my donor car. The donor has a lot more corrosion than the build car, and it has been a serious PITA to get the transmission loose. My desire to have the tougher hear box keeps me going.
I'm pretty excited to test fit the 5.3... Just waiting on the new tap and die set.
A bit more progress...
Today I mocked up the seats to weld the brackets in place some time in the future. I also test fit the new engine on the TPC motor mounts, and painted a bit of the engine compartment. Getting the spacers between the rails and the cross member wasn't fun. I drilled and re-tapped the hole with the broken bolt and... success. Everything is solid now. One last thing, finally liberated the turbo trans from my donor car... a lot of corroded bolts... drilled and angle grinned the damn thing out.
It's amazing how much free time I have, since I'm not working right now. I guess the car is filling the void for now, keeping me busy, and keeping my mind from wandering too far off course. There isn't many other things as soothing and satisfying as spending a day in the shop. Don't tell my wife... but I guess you wouldn't have too, I think she's already got that one figured out.
Re: Frosty's 83 944 LM7 Project
Nice, keep going!
Details...
Getting into the weeds now. I've got the new flywheel on the engine and I'm working on getting the turbo trans cleaned up. I set the intake manifold on too, just to enjoy the view for a bit. I'm digging into the braking system as well.
I have the bias valve from the turbo car, to go with the little black calipers, but I'm not aware of the differences between the porsche master cylinder and the suggested wilwood 260-8794. I'm considering fabricating my own plate to mount the factory master cylinder without the brake booster, but in the same location. It seems like the diameter is about the same as the wilwood model, and the brake lines don't connect on the bottom, eliminating some of the challenges with heating by the exhaust manifold. It feels like I must be missing something, why don't people run it this way?
Clutch, Torque Tube, MS Plate
Here's the latest updates... The clutch and torque tube are on. The splines on the drive shaft had some trouble going into the splines on the clutch disc (from TPC). Fortunately, after several hours of struggling, I noticed that the engine mounts weren't sitting symmetrically. The left mount was all the way to the rear of it's adjustment range and was causing the entire engine to sit at an angle in the engine bay. After loosening, prying, and cursing a little, everything was squared up and the shaft went into the disc without complication.
I'm also having my father fabricate a master cylinder to firewall adapter plate out of 1/4 inch aluminum. I'll be reusing the factory master cylinder with the 86 turbo biasing valve to accommodate the 4 piston calipers.
Fabrication and Shipping
I'm going to try and take the car with me when I move back to the west coast... unless a reasonable offer comes around. With this in mind, I've taken to trying to prepare the car for shipping by getting the hatch, doors, hood, and glass back on it. I've got a new windshield going on it on Monday, for a bit less than $300, and I managed to jump the window motors with an extra battery I had lying around in order to get them closed.
Also making progress on several other fronts. I received the adapter plate which my dad made for the brake master cylinder. It looks like it's going to be a good fit, and should cant the MS away from the driver's side head, to give a little more room. Now I need to track down some hardware to get everything bolted up.
I ordered a piece of 1/2 inch aluminum stock to make an adapter plate, which will allow the 86 turbo transmission with intercooler to go on the 83 NA mounting points. I had to order a few new cobalt drill bits in order to get the holes the right size.
The water pump spacing kit I ordered arrived yesterday and looks like it will be a good fit. I still need to pickup an F-body water pump and belt tensioner.
Last, I mounted the Kwik alternator bracket, and it looks to be of reasonable quality. Testing the hood clearance the setup should work well, the alternator sitting slightly lower than the ls1 intake throttle body, which just clears the hood.
More Progress
Made some minor progress... ordered some 1/2 inch aluminum and made an adapter plate to mount the turbo trans onto the early 83 mounting points. I drilled and tapped the bar stock to bolt the transmission straight onto it.
I also got a new windshield installed today. Safelite was quick and painless, and it only cost $270. It's nice to see the car coming together.
The brake master cylinder test fit went pretty well, looks like the adapter plate is going to work. Now I have to drill the pedal arm in order to line things up and increase the leverage.
Transmission Plate
Got the transmission bolted back in today, but not yet attached to the torque tube, and removed most of the spare tire well. I elected to go with the early transmission mounts, the passenger side only being attached by two bolts. This seemed more prudent than fabing the adapter plate that I was working on. I imagine that the mounts will be strong enough, as the turbo trans mount is only two fairly small, maybe 8 mm bolts. I also got an f-body water pump, belt tensioner, and MAF sensor in the mail, along with a painless performance wiring harness. All in all, it looks like the next few days should be fun
I may be missing something but man I don't think the master cylinder is gonna be very happy without the 12 degree angle.
944-LT1 wrote:I may be missing something but man I don't think the master cylinder is gonna be very happy without the 12 degree angle.
Could you please explain... I'm all ears if I can learn something.
No problem. The stock master cylinder was bolted to what we call the cereal bowl which is just a mount that bolted to the firewall and gave the master cylinder a 12 degree angle with respect to the firewall. This allowed the brake pedal pushrod to push in-line with the master cylinder piston. Without the angle, the pushrod would enter the master cylinder at such an angle as to cause the piston to score the piston wall thus damaging the cylinder.
Heres a picture of the stock "Cereal Bowl" with a plate from RH bolted to it.
Heres a wedge I had made to bolt to the plate that replaced the cereal bowl.
Heres the setup out of the car to measure the stock angle.
Heres somebodys angled wedge in place.
Transmission
The transmission is on and the spare tire well is mostly removed. I have yet to address the brake MS, but I will get to it.
Sombody's wedges
Somebody's wedges...........mine.
Don't forget to reinforce the firewall!
simon123- Posts : 125
Why did you put a spacer on the waterpump? U plan on using a truck crank pulley?
matt889- Posts : 214
Just a heads up, i spent much effort trying to retain the truck accessory spacing and it looks like you plan on doing the same (spacers on the water pump, not changing the crank pulley, etc). If you get a thicker than stock radiator, like one of the many 3" versions that will fit, you're going to have difficulty fitting a fan(s) that will provide any significant air flow.
I ended up changing the accessory spacing to the f-body spacing. Buys you ~3/4" inch and is definitely the easiest way around the problem.
FrostedFlakeJake- Posts : 263
Page 1 of 2 • 1, 2
Page 1 of 2
