Hydroboost Parts List
+8
948inVA
zeusrotty
Psychoideas
rdanford
12 posters
Page 1 of 2
Page 1 of 2 • 1, 2
Looking for verification on the parts list for hydroboost....Thanks in advance!
1. PS Pump w/ Reservoir
- RockAuto Part #ATSCO 63105
- $82
2. Billet PS Bracket for F-Body
- TPC
- $60
3. PS Pulley
-GM Part #12559885
- $55
4. 2000-04 Ford Mustang Hydro Unit & Master Cylinder
- Used/Ebay
- $150
5. Hydro Unit to Firewall Mounting Plate
- TPC
6. 2 HP Lines
7. 1 LP Line
8. Various Fittings
9. New Belt
If anybody has any of these items used and in working order also let me know.
Thanks Again,
Royce
- $82
- TPC
- $60
3. PS Pulley
-GM Part #12559885
- $55
- Used/Ebay
- $150
- TPC
6. 2 HP Lines
7. 1 LP Line
8. Various Fittings
9. New Belt
Thanks Again,
Royce
rdanford- Posts : 96
Re: Hydroboost Parts List
You might want to add a power steering cooler plus lines as well as the Turn One PS pump to that list...
Remember I don't have power steering...I actually enjoy the feel of the manual rack.
The power steering pump runs the hydroboost. You don't want that fluid to boil. The cooler and Turn One pump will ensure that doesn't happen. Remember our conditions are very different than everyone else's on the board, we're the only people dealing with altitude...
Good point...I'll call and talk to them tomorrow. The car is currently at a shop b/c of the electric brakes but I might try to complete the hydroboost setup at home and save on the labor side.
Is this the correct hydro unit?
http://www.ebay.com/itm/99-04-Ford-Mustang-Gt-Cobra-Mach-1-4-6-hydroboost-1210-/181077080883?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a2908fb33&vxp=mtr
That's the one I have, but it throws off the rear brake bias. You need to install an adjustable brake proportioning valve with it. I have a spare tilton one if you need it. The BMW system reuses the stock 951 master cylinder so the brake bias isn't thrown off
Make sure that you get the line/hoses that go with that hydro boost. There is not an aftermarket fitting replacement for one of the pressure lines.
Port threaads
Does anyone know the size and pitch of those ports in the hydro-booster? They look similar to the ports in the BMW unit, which I got adapters to convert the high pressure lines to -6AN.
This seems to show all the fittings needed to make new lines...very detailed write-up.
http://classicbroncos.com/forums/showthread.php?t=147997
Those are not the same as the Mustang hydro boost that I have seen. They will not work on the ones that I have been using.
Bmw hydroboost?
Hello all,
Does anyone know of a good source for the BMW hydroboost system or what is the correct terminology I should use during my search?
Regards,
Frank
Regards,
Frank
Psychoideas- Posts : 36
7 series from 84-88, the system is referred to as H31. Frequently they show up on ebay, and frequently the are overpriced.
Thank you 87,
With that information I will try and find one from a BMW wreckers, down here in OZ.
Sorry for bringing up an old thread, but I don't get how the hydroboost lines connect to the turn one ps pump, or the rack. Is there an over sized banjo bolt or two that I'm not getting? I've decided to scrap the electric power brakes... Just can't take it anymore.
zeusrotty- Posts : 444
Welcome to the club...has been the only problem with the conversion to the point my wife won't get into the car without a different brake system...I have all the parts but the turn1 pump as it's on back order
You can use metric to AN adapter fittings; That is the way i would do it.
Techno Duck- Posts : 447
No I get that. I don't get how the lines are routed, and then how they are attached when there are already lines to and from the rack and the pump. Does anyone have detailed pictures of the pump and the rack with the lines already attached? That would help allot.
Posted this in a few threads here already, did you search? This is how the plumbing should look:
948inVA- Posts : 224
Ah, I get it. So basically I am just rerouting my current lines and teeing off of them. And then I also have to change a few of the ends. Correct?
supes6 wrote:Posted this in a few threads here already, did you search? This is how the plumbing should look:
Thanks for posting again, the pic is extremely helpful!
Make sure you guys are having high pressure lines made for ATM fluid resistance. The ebay compression fittings are good for fuel pressures (60 psi) but not PS pump pressures (800-1200 psi), especially when turning lock-to-lock....
I had my hoses made at Pirtek because I knew they did good work, but Discount Hydraulic has started doing custom hose assemblies and it looks like it's about 1/3 what Pirtek charged me. Just another possible option.
haroldk- Posts : 140
yes we have a place up here that makes custom hoses. They have done a few things for me on the Porsche... They actually did the power steering hoses that are on the car now, so I will probably just have them knock these out also.
Question: I'm not running power steering, can I get away with a Chevy power steering pump and no cooling lines with the mustang hydroboost?
Does this setup look correct?
Page 1 of 2 • 1, 2
Page 1 of 2
