Wanted: Stock Clutch setup for an early 85 944
Bought a project cat for my son and I. We've been slowly getting it running and the next broken link is the clutch. We need a stock clutch just to get her mobile while we determine what motor to go with. Let me know what you've got.
SOB Racing- Posts : 22
Re: Wanted: Stock Clutch setup for an early 85 944
I've got a spec pressure plate, same as stock except slightly higher clamping force. A spec disc with about 70% material left. And a release bearing with less then 10 miles on it.
I'd take 150 plus shipping. Which might be kinda expensive cause the stuffs heavy.
Pm me through the forum or [You must be registered and logged in to see this link.]
thanks
thanks
phlip- Posts : 67
Sent you an email since I don't have enough post to PM
I have a stock clutch disc in good shape I'll sell for cheap. I also have the pressure plate/TO bearing/etc if needed. Shoot me an email at [You must be registered and logged in to see this link.]
admiralkhole- Posts : 62
I got a setup from phlip---hopefully I'm set!
» Selling off my stock clutch parts and RH clutch disc
» Wanted! Stock LS1 airbox parts
» Stock LS1 clutch parts on the cheap
